1 (edited by pwalchester 2017-11-25 08:54:20)
Topic: KBOS taxi routes for Boston Logan Intl by MisterX6
Taxi routes for KBOS Boston Logan International v1.0.0 by MisterX6
Re-positioned taxiways and gates
Place in X-Plane 11/Resources/plugins/X-Life/Airports folder
There is now also a no-static version which is the larger file.
109 gates/stands, 2 stands left unused due to parked ground equipment.
Some gate numbers have changed in-line with recent airport chart. As usual starting gates are those provided by airport creator but all other gates are live for arriving/departing X-Life user and AI aircraft.
Flows checked and seem OK, including cargo and GA, any problems let me know and I'll take a look.
Settings used for flow checks
Air Traffic Density 80%
Airport gates/stands busy 45%
Runway operation interval 1.7 mins
2 (edited by rcbursey 2017-11-20 04:26:44)
Re: KBOS taxi routes for Boston Logan Intl by MisterX6
Nice work and thank you. Will this work with the previously posted no static scenery for the misterx6 airport?
Yes, but newly vacated gates won't be used. They can be easily added but may take a while if you're not used to the editor. Otherwise I can produce a no static version if you like, point me to the no static scenery file in this case.
4 (edited by rcbursey 2017-11-23 18:37:59)
Oh that would be real nice if you did that for us. Here is the link for the previously posted no static for misterx6 kbos scenery. This obviously isn't his latest version. Thanks so much. Btw, ur work is excellent!!!
http://jardesign.org/forum/viewtopic.ph … mp;login=1
See main post above for no-static version
