1 (edited by pwalchester 2017-08-06 05:57:53)
Topic: KJFK taxi routes
New format taxi route file (.xlf) for KJFK V2.2 airport by X-Codr
Taxi routes cleaned up, Hold Areas added.
This file is also OK for V2.1 if you can live with taxiways and stands on undeveloped ground between terminals 3 & 4
Also OK with stock XP11 KJFK if you can live with a few taxiways clipping grass areas - if not it is easy to modify this file with X-Life Airport Editor
Place in X-Plane 11/Resources/plugins/X-Life/Airports folder
Re: KJFK taxi routes
pwalchester wrote:
New format taxi route file (.xlf) for stock XP11 KJFK New York airport
Taxi routes cleaned up, Hold Areas added, Taxiway and stands removed from undeveloped ground between terminals 3 & 4
Which KJFK scenery is this for?
Apologies, this is for KJFK by X_Codr, V2.1.
There has been  V2.2.2 published which I have not yet checked, or seen till now. V2.2 has updated ground routes so may or may not need .xlf editing.
