1 (edited by Flavour Flow 2017-07-09 18:07:44)
Topic: B738-800 modified (zibo mod) Set (NEW VERSION 1.1!!!!)
This is a set file for JarDesign's GroundHandling Plugin supporting B738-800 modified (zibo mod)
...it contains:
GPU with Cones
2x Loader
1x Fuel Truck
2x Stairway Vehicles
2x Catering Vehicle
2x Cones in front of the turbines
1x Neoplan
1x Limo
1x Van
1x Ambulance
3x Chocks
I´m not a programmer so it was hard work for me to create this Set! I did my best and it takes a couple of hours, but i´m very happy with the result! smile
Installation: Put the File "Boeing737-800x.set into: X-Plane 11/Ressources/plugins/GndHandling/Sets/Custom.
New Version 1.1  (Jul. 09.17)
What´s new:
optimized "DRIVE UP & DRIVE AWAY"   (Vehicles no longer drive against each other)
optimized Stairway vehicle position
Better GPU connect &disconnect animation
Better general movements
Re: B738-800 modified (zibo mod) Set (NEW VERSION 1.1!!!!)
Installation: Put the File "Boeing737-800x.set into: X-Plane/Ressources/plugins/GndHandling/Sets/Custom.
Thank you so much.This is great.
Hi, Thanks for the update, however I am not getting any stairways?
Morning,
I have the same problems, don't see the stairways !!!
I'm not seeing any objects when I try to use this with the zibo mod and ground handling. Using the stable 3.06p zibo mod. Ground handling works with default 747. Anyone have the same problem?
Mine just started working randomly tonight. I'm not sure what happened to fix it.
Wanted to ask this question. When the baggage loaders pull up to the plane, I see the suitcases and boxes. Is there anyway to have the suitcases and boxes going down the loader instead of always going into the plane? When you arrive at a destination you first need to unload the cargo you have, then load new cargo.
About the problem with not seeing the ground handling, did you guys set the parking break of the zibo 737?  because default it is not set, so first you have to set the parking breake then also the ground set is working
Thanks for this!!
Great job. I adjusted it a little bit (Wheel chocks were a little bit of and some other parts were to) Maybe I have an other model or something, also I added a second bus.
