Can't confirm the "flight plan part fixed" feature of this version:
I'm having slight problems with the A320 MCDU. I'm trying to program a STAR arrival to EDDN ILS28, coming from EDDH. So I chose the available ILS28-Z in the MCDU, chose the "NIBIL 6T" STAR and then I would take VIA "PIVIR 28 RNAV", but only the "ERLANGEN" is available, which would be for non FMS aircrafts.
So I went back to the F-PLN, again took "ILS28-Z", "NIBI6T" and now the other VIAS were shown. So I took the "PIV28", no transition and inserted it to the plan. When I checked the Plan I saw, that the way points were mixed with other STARs and so completely useless.
After that I started searching through the forum, and found out, that this is nothing special, when the A320 MCDU misses a STAR / SID or has some wrong way points in it, because it uses the NAV-data from X-Plane in first place. But after that I tried to build the exact same approach in the 737-800 from Laminar and it worked out without any problems.
So I'm a bit confused. How can be there a difference in the way points, when both MCDUs use the same data? Is there a way to fix this by copying any NAV-data or something like that?
I also checked the way point txt.file in the A320 nav-data folder and the points are set correctly like they should be according to the Navigraph chart:
APPTR,I28-Z,28,PIV28
IF,PIVIR,49.667081,11.416064, ,0.0,0.0,0,0,0,0,0,0,0,0
TF,DN411,49.731758,10.756347,0, ,0.0,0.0,0.0,0.0,0,0,0,0,0,0,0,0
TF,DN422,49.632925,10.734056,0, ,0.0,0.0,0.0,0.0,0,0,0,1,240,0,0,0
TF,DN425,49.589167,11.184889,0, ,0.0,0.0,0.0,0.0,2,8000,0,0,0,0,0,0
TF,DN426,49.572725,11.349400,0, ,0.0,0.0,0.0,0.0,0,0,0,1,220,0,0,0
TF,DN429,49.541742,11.652786,0, ,0.0,0.0,0.0,0.0,0,0,0,0,0,0,0,0
TF,DN436,49.443103,11.628714,0, ,0.0,0.0,0.0,0.0,0,0,0,0,0,0,0,0
TF,DN435,49.453503,11.527817,0, ,0.0,0.0,0.0,0.0,2,5200,0,0,0,0,0,0
CF,CF28,49.471444,11.350611,0,INUW,96.6,11.7,277.0,7.0,2,4000,0,0,0,0,0,0
The NAV-data from X-Plane is updated to N1705 by Navigraph and the A320 MCDU also shows this as the active nav data base.
Also created a ticket for this, but maybe anyone else had this and knows a solution.
Thanks for any help / answer!
