51 (edited by David086 2017-05-05 19:13:33)
Re: JD320 Airliner ver 3.1r1,r2 WIN/MAC 64 bit (X-Plane 11)
Two issues with the pressure setting nob,
-The setting on the control panel and PFD don't match up (see pic)
-When clicking the pressure setting right to increase it actually decreases and vice-versa, it's inverted needs to be the other way around
Attachment icon Screen Shot 2017-05-05 at 20.05.57.png 613.11 kb, 168 downloads since 2017-05-05
Anyway BBS v3.1 still working flawlessly with A320 v3.1r2.
Looking forward to the .Org store uploading BBS v4.
53
When you purchased V3.1 there should have been a download link. Try it again.
54 (edited by Acei 2017-05-05 21:09:34)
Flight from EIDW to EGCC.  Wind on approach was 16 knots.  However plane was acting like it was in much stronger wind.  Eventually banked hard and crashed on final.  Not sure if this is a problem with the plane, my weather app (SM and RWC) or XP.
I got mine from xplane.org and the emailed download link still points at v3.1
Same here sad
57 (edited by ilankrt 2017-05-06 12:44:51)
JAR A320 v.3.1r2 + XL
Test Flight from KBOS to KJFK
There are some serious problem discuss:
1. On approach ,flying 2 100º/90º turns at the right flight level to catch LOC + G/S (APPR call and activated) and the aircraft is flying twice out of curve although as a precaution I reduced speed before to 160/150kt. Question: is there an implemented limit for flying a turn >90º? Flying manually to straighten with RWY I could finally catch G/S....
http://jardesign.org/forum/img/m/1591/t/p1bfeskpcd14i61hse17d22nl4np5.jpg
2. I used to check my landing with the replay mode. After turning replay off aircraft  immediately push throttle to full and the aircraft is moving without any possibility to stop it. this treat must be taken care urgently...
3. There was the problem that ATC don't accept DCTs in Flight Plans (KBOS SID SSOXS DCT BUZRD DCT SEY STAR  KJFK) This problem occurs now for new !!
Beside this problems everything was going well during flight.
58
roberto.valdomiro wrote:
Don't find... link please?
Use link used for V3...
x-plane.org nothing here :-(
link is not on x-plane.org...
link is in the mail you receive first time you buy bss sound pack...
59
there is ony a confirmation mail from xplane org nothing else -.-.Bss support isnt good:sorry
BSS V4, Try going into your google drive account it should have been shared with your google drive I think at least that's how I got mine.
G
61 (edited by Dbader 2017-05-06 09:29:40)
Hmm can't find my original email yet it's showing in my .org store account - but only version BSS 3.1
I assume the .org store will update the file sometime soon???
Correction: found original email but it's just a link to the .org store page.
Constraints:
It would be great if these appeared in the PFD!
63 (edited by ilankrt 2017-05-06 12:13:48)
I wrote to X-Plane.org store and they answered that they will apply to BSS soon
BTW BSS v3.1 is working well with A320 v3.1r2
64
Sorry guys for disturbing your discussion about BSS4. wink
I've a small problem with my A320 (JD320 V3.1R2 - X-Plane 11.01r2). After completing a flight, i would like to start a new one without reloading the plane or restarting XP. So i start entering the new flight in INIT page. Then i switch over to F-PLN page. There i can't select a SID in Departure section. I tried this several times on different airports. Is this a known problem? Or am I doing something wrong?
Kind regards
RevLoewe
Kind regards
RevLoewe
I've the same issue, if i need to change my SID after i selected one, i can't if i don't reload the plane, the page shows as blank.
G
Interesting. My google drive only has a link for the original BSSv1.1 file
67
Test Flight from CYYZ to KORD
1. Cannot activate FMcar from ATC
2. Initial altitude 20000ft seems to be strange
3. X-Plane ATIS is steady on frequencies of Ground Tower only switching to Approach and Center can stop it
4. At 17kt front wind aircraft is swinging hard to control (Camera shake off) This was a big problem in the past that occurs again
5. After deactivate the Replay mode aircraft became a "Space Ship" https://youtu.be/t2gviifEei4
68 (edited by dimkzr 2017-05-07 03:25:26)
Maybe it's the X-Plane bug, not JAR's?
I had similar behavior with FF757 today (XP11.01r2)
Can you please test it with other aircrafts?
thank you for modelling this wonderful plane!
I have an issue with selecting arrivals. Unfortunately, I can't select any transitions (example: EDDL, DOMUX23 transition). I just get offered the STARs, but not the transitions. I checked the navdata-files (AIRAC 1705 from navigraph), the transitions are in the same file as the STARs. Any idea how to fix this?
Got the same Problem...
Xplane Navdate is up to date (1705) and I put the Jardesign Navdate up to date (1705) as well and both navdata sets indicated in the MCDU can be chosen but with none of them I have transisiotns!
Example in Munich ( EDDM) ROKIL26 and oll other completeley missing !
Even if I delete JAR Navdata and FMGS uses Xplane custom Navdate and vice versa.
[img]http://status.ivao.aero/143310.png[/img]
[img]http://froom.de/img/froom.png[/img]
71
Hi, I used to make a video from every flight and at the end to to go to replay to see from outside how good (or bad) my landing was. From my experience with JAR models I know that when disabling replay mode I have immediately disconnect AT because JAR aircraft are somehow tuned to full thrust ... But this time it didn't help. I couldn't do anything before the "space show" began.
I don't think it is a X-Plane bug.....
72
Hello smile
Some intresting thing - I landed in EPWA ( from ELLX), no problems in flight. Turned off engines (pirep reasons), and then for replay turned it on again, set flaps for landing, arm spoilers. Then I went to replay mode, made some movies...
And when I click to main (turned off replay mode), plane had accelereted like intergalactic speceship (without chaging me anything), went for FL600, everything was not working...
It`s 3rd time (3 tries wink ).
And if I can say - smoke from engines.... Its terible... Black... like some old, broken UAZ wink
Regarts wink
73
I noticed that the RED250 does not work anymore as intended. The plane does not decellerate above FL100 down to 250kts while in descend mode. When passing FL100 the plane wants to go down to 250 kts but it does not level off or so. This was the only thing which came up with a little surprise.
Furthermore, can anybody of you tell me how to correctly operate the weather radar? I really have trouble using it. Which mode do I have to use, once the radar is engaged and how can I make sure the weather is corretly displayed on my ND?
74 (edited by gsuri 2017-05-08 09:55:42)
Hi Mr Romanov
The BSS 3d-1 or the Jar 3d plugins don't load with v3.1r1 or r2.
I see the 1114 error in the log.txt. However, my system has a GTX 1080 card with a Nvidia driver.
The plugins load in 3.0vr5 and r6 but no engine sound is heard.
I am using the same plugins and scenery in X-plane 10.51 and everything works fine.
My log.txt is attached
thanks
GSuri
EDIT (SOLVED): Problem traced to Xenviro with XP11.00 and 11.01
It was causing problems with FF aircraft too.
Removing it solved the problem.
EDIT: the problem persists with XP11. MAybe its the new Nvidia driver 382.05. I am checking
Thanks for confirming this behavior. Then i hope, this will be fixed in next release. wink
