Re: JD320 Airliner ver 3.1r1,r2 WIN/MAC 64 bit (X-Plane 11)
I am confused we had until now v.3.0r6 and then JAR say r2 ??!
JARDesign Group Board → Download, Updates → JD320 Airliner ver 3.1r1,r2 WIN/MAC 64 bit (X-Plane 11)
3.1 r2
GaelMebiame wrote:Hello,
When I start the number 2 engine first it spools up to TOGA power and I endup having to shut it down and start with engine 1. Any ideas?
Best Regards,
GI will check this. Thanks!
..sadly yes. Will post fix today/tomorrow. Sorry.
Until fix - need start eng1 first.
Thanks for the very quick attention to this, J.A.Romanov hope it all goes well!
Best Regards,
G.
Just to make sure: BSS 3.1 Soundpack isnt working with this version? At least for me theres total silence...
BSS V4 works great...if you have purchased directly from BSS web site, please use your download link of previous version.
You need to delete the 3dsound folder, I think it was called, as stated in the installation instructions for the sound pack.
By way of explanation, each time you upgrade the a320, that default sound folder is recreated and as that needs to not be there, for the new sounds to work, just delete it again.
The latest version of the A320 is working well - many thanks.
I bought the BSS sound pack from the org store and V3 doesn't appear to work with V3 R2 of the A320.
Anybody know how to obtain V4?
JAR, what about sudden movement to E46 airport?
I'm honestly afraid to fly now, knowing this bug may occur.
Dimkzr;
i tried one thing it probably fixed for me
Run Xplane updater and choose the option saying "Update Scenery Online"
it downloaded 10GB of files for me and i made the same flight and didn't face this bug.
Probably this Bug is because of earlier Beta Builds of Xplane, and this is what is written in their site
let's track the issue and try again
good luck
Ah okay, bought BSS from the org store. No sign of V4 there... At least not last night.
I tried last night to load a flight plan from Simbrief (Jardesign exported option) into the MCDU as always, but this time I got an error message saying that the Flight plan was not loaded. The problem was that then the whole MCDU stopped working so I couldn't make any input. I didn't have time to do a second try (I'll do it again this weekend) but I'm wondering if someone has experienced something similar.
If you bought BSS on the BSS homepage -> Use the same download link where you downloaded V3. If you lost that link, contact the author.
If you bought on the X-Plane store -> Look at the download link in your products. I'm not sure if the author has updated that version yet.
Just checked, no sign of it at the org store yet.
Is BSS v4 out now.Dont see it.Bought it at org store
Not yet it seems..
Paddy wrote:Is BSS v4 out now.Dont see it.Bought it at org store
Not yet it seems..
I posted a question on the BSS Facebook page about this, but no response (yet). Guess we will have to wait.
Perfect flight LFBD-LFLL
no bug ;-)
bss v4 ok
no bug ;-)
bss v4 ok
BBS v4 is out?
enrigolan79 wrote:Perfect flight LFBD-LFLL
no bug ;-)
bss v4 okBBS v4 is out?
Yes, download this morning...
Flight from LSZH I put the Baro correctly and got 1300 ft above sl. It should be 1416. When I went into Vatsim I saw the other planes above me which means, that I was in their system to low.
I have the BSS A320 sound pack (v3) working fine. However, as I said in my earlier post, you need to remove the 3dsound folder that the A320 update process creates.
Reread the installation instructions for the sound pack and delete the folder as it suggests. As the BSS folder should still be there from when you first installed it, that will be all that you have to do.
roberto.valdomiro wrote:enrigolan79 wrote:Perfect flight LFBD-LFLL
no bug ;-)
Don't find... link please?
enrigolan79 wrote:roberto.valdomiro wrote:BBS v4 is out?
Use link used for V3...
roberto.valdomiro wrote:enrigolan79 wrote:Yes, download this morning...
x-plane.org nothing here :-(
I dont know if you have noticed this but, when I am taking off and set Man Flex takeoff, N1 accelerates to about 80% and THEN slowly rises to T.O N1 that it should be... Is this normal?
Thanks in advance,
G.
