Topic: Busy Airport: X-Life ATC Routes for EDLP Paderborn (default) v1.0
ATC Routes for Paderborn-Lippstadt Airport EDLP (X-Plane default). Spending a lot of time into traffic optimization, but there are still some issues (see below).
Comments are welcome. Also pls post any issue, but read the notes and known issues first.
Features:
- Added some addionally stands for more variety.
Notes:
- Some of the "hold short" positions are set more close to the runways as shown by markings. This belongs to the taxiway design and some limitations of XL.
Known Issues:
- Airplanes leaving positions A, B, C, D, or E can touch other planes when turning out. It belongs to the small space and in combinations with the types of aircrafts.
- On Gate positions, Airplanes are touching the gates while turning out because the gates are static, only. Real gates are moving to a parking position to give clearance for the turning plane.
- In some rare cases airplanes performing an u-turn over grass at the end of the runway. This happens only after using an alternate way to solve a conflict with other planes.
Tested in X-Plane 10.51 on Win7
(w) 03.05.2017 @ Haddock
Attachment icon BusyAirport_ATC-Route_EDLP_Paderborn_default_v10.zip 5.49 kb, 192 downloads since 2017-05-03
