Topic: Aerobask EPIC E1000 Set
Due to the small slots on typically GA ramp areas this setup is made to use less space for the animations to fit much parking situations. However, you should use parking positions with empty slots on both sides, if possible, or choose a ramp positions of the next higher aircraft category (e.g. turbo liners).
Notes:
⁃ There are no GPU and chocks in this setup because they are included well modeled in the aircraft model.
⁃ Due to the limitations of the fuel truck animations I preferred making a wrong fueling connection instead of a lonesome fuel truck standing there without any sense.
Created and tested on Win7 and X-Plane 10.51.
Version 1.0 (w) April 22, 2017
Haddock
