Topic: Ground Handling movement not smooth in Xplane11
The movement of the Ground Handling vehicles in XP11 is not smooth but seems to "surge" in speed about 4 times a second.
Other built in animations are smooth.
JARDesign Group Board → General Discussion → Ground Handling movement not smooth in Xplane11
yes. I have the same issue
same here :-(
me too - very jerky
same for me
I found this was happening when I had tug master installed in 11. When I took it out, the problem was solved.
I'm gonna give it a try. Thanks for sharing!
Same for me, except i don't have tugmaster installed
Does any one know a fix for this ?
If i turn down the Reflection all to the left to "minimal" the stutter stops and Ground handling as well as follow me car animations are smoth again. Any fix ? (other ground cars on the airport run smooth even with high reflections wich rules out weak cpu performance for me.)
