251
holman.donald wrote:
Has Anyone else had this Problem?..on the  A20..V3.6B The radio light will not work for me in XPlane 11.B15
I am using..
iMac (Retina 5K, 27-inch, Late 2015
4 GHz Intel Core i7
32 GB 1867 MHz DDR3
AMD Radeon R9 M395X 4096 MB
mac os 10.12.3
Xplane 11.B15 (64 bit)
X55 Saitek Pro Rhino Stick
X55 Saitek Rhino Throttle
I have the same problem
252 (edited by ilankrt 2017-03-18 10:56:38)
Test flight EIDW - EGLL ends with a total system failure (SASLE ERROR) ! (A320 b5)
See log.txt
253
Hi after using new version 1.4.5 of A350 from FF I can no load a co-plans to A320 and A330 from JARDesign. Is it  a know bug?
254
I just get test XP11 build from Laminars - ILS (LOC&GS) dot indication work well. I expect what this fix will be include in next XP11 public beta and we will done this ILS issue.
http://jardesign.org/forum/img/m/22/t/p1bbgf1hdi1rhbn43hh01jh916rb3.jpg
255
rhpa23 wrote:
I have problems to complete a flight. SASL ERROR
I'm using XP11 PB14 and JARA320 V3.0B5
Any idea?
http://jardesign.org/forum/img/m/718/t/p1bavdapup14i7sccvliunbca93.png
Log when error start:
124thATC v2.0-a53 15:59:12 : ILS Path set to RWY 21.
124thATC v2.0-a53 15:59:12 : Take arrival runway 21
[SASL INFO] "mcdu_fpln"    --> Set active WPT to 17L for APT_DEP/DEP_RWY reason
[SASL ERROR] Error updating avionics: [string "u//mcdu_fpln.sec"]:0: attempt to index a nil value
124thATC v2.0-a53 15:59:12 : reading acc.dat
Yes I have the same issue. It seems there's an incompatibility with 124th ATC plugin when you select another runway option for landing, SASL crash. Is there anyway to solve it?
256 (edited by ilankrt 2017-03-18 11:01:30)
Any idea?
JAR:  I think I have the same SASL problem - See my log.txt file in post 252 !
257
Hi everyone.
Flying with keyboard, I have an issue with thrust levers. With the command "Throttle up a bit", I can't go to CLB position.
See attached pic please. Worked fine with XP10
any help?
Thanks a lot
Attachment icon Capture d’écran 2017-03-18 à 18.03.38.png 826.78 kb, 176 downloads since 2017-03-18
258
Hello... I am kind of frustrated right now. Bought the update, but have noticed a drop of 3 to 4 fps (not a very big for me), and one of the most important things in the aircraft is not working. ILS, I do take off right after liftoff of my ILS needle and glide slope is stuck. I have no positive guidance of the instrument. The only way to have a positiveness is in manual mode engaging LOC, but I will only have positive guidance in the pfd. In the ND, everything is stuck  ... (when it decides to work)... I did take every single plugin out and flew the a320 v3 with plain and raw x-plane... the errors persists... can someone help me please? It does not happens with the latest v2.7.
https://youtu.be/nUy8P1gP5W8
259
For heaven sake Why ILS engage at take off!? You should have known that  ILS  a n d  LOC is used for landing.......... You don't need help you need to read or view a tutorial video about flying airliner here the A320neo
BTW no specification ....
260
Test flight EGLL - LFPO  A320 b5
1. FMcar not activated over ATC
2. Right after TO problem to get from FLEX to CLIMB (if I am flying manually and not engaging soon the AP
3. Ennoying and disturbing light ball (sun? I turned all light and saw they are not the source) again and again on instruments (I had already published some images)
4. Speedbrakes didn't deploy although green announcement on right ND !  (Not to use during descent and on runway)
5. Reverse engines didn't work
261
Before u tell me how to fly the airplane... please learn how the system is suppose to work... do u know what is an ILS? Do you know how it function? I did a flight before doing that video... and reason for writing here is that I believe the system in v3 is not working as it should. Might be a script issue or whatever...I don’t know if u have flown in a real airliner like I do... but some people leave their ils frequencies of the departure airport ready... in case they have a problem and need to come back... u need to always be ahead of the plane when flying jets.... watch the video I uploaded and check the approach... I take off, and then return for an ILS approach and landing... but thanks for your post... I hope u have a more constructive answer next time
262
Excellent, thank you.
263 (edited by crisk73 2017-03-19 09:31:46)
I can confirm points 4 and 5. In particular speed brakes deploy only if you make a hard landing at -500 fpm and above, but when you land softly they don't work.
As for reverse thrust it activates but it seems not to slow down the plane. In all of my recent landings I found myself in the grass for those reasons.
264 (edited by ilankrt 2017-03-19 14:25:59)
I forgot to mention an importent bug: Disconnecting AP at 1000ft for landing manually and aircraft pitches extremely up - that is an occurrence that must be urgently regulated in the next beta version.....
265
Today I tried an Autoland with the AP connected. In this mode speed brakes deploy correctly. In manual mode only at high touchdown rates.
266
I'm having problems with the autopilot.
It keeps disconnecting and I cannot get it to stay on !
This is true for both the 330 and 320 running XP11pb15
267
268
I have no issues with either aircraft... using XP11 b15 with latest Airbus betas.
269
I can't see the radio buttons and transponder box buttons during night they're just black buttons. Using all latest betas.
270
For me the autopilot disconnects if the weather is not CAVOK.
271 (edited by dimkzr 2017-03-20 01:19:58)
Does anyone else seeing weird lines on cockpit windows? Jar beta 6, XP11pb15. Changing livery or anti-aliasing settings doesn't help.
272 (edited by lanmancz 2017-03-20 12:05:27)
The built-in pushback with the A320 does not work very well:
a) it's crazy fast
b) the arrows are "reversed" - this always gets me, I often pick the wrong direction (ie. to turn nose left you have to select right arrow which is a bit counterintuitive tbh - all other pushback solutions I know reference the nose direction, not the opposite backward motion)
c) it's wobbling during pushback, the pushback tug often "collides" with the aircraft and they both jump and bounce weirdly
d) today it went completely mad - it wasn't able to hold a straight back line and started turning (I didn't command any turn! just straight back) so I clicked "go" again to stop it but it just kept turning, doing circles faster and faster so I clicked "bye tug" to get rid of it and stop. That didn't help, the tug disconnected but the aircraft just kept spinning on tarmac. Setting parking brake on or off or holding down brake pedals had no effect, plane kept spinning. I only managed to get it to stop by starting up and firing the opposite engine to counter the spinning motion. After that though 2 of the aircraft wheels were weirdly submerged in the tarmac so I pretty much had to quit and start over.
I'm running XP11b15 with A320v3b6.
PS: I'm not sure if the tug uses the same/similar logic as the vehicles in GHD but I've seen similar thing happen with them when creating custom sets - when they miss their mark they keep spinning in circles around it. Seems pretty similar to what happened to me today with the pushback.
PS2: The engines are still wonky - shutting down during taxi when set to idle, then restarting. Happened to me just now during taxi 3 times.
273
I have the same issues have tried everything to get rid of them but with no luck...
274
I see the same from distance but not when zoomed in. I expect this is a render issue and will not use any more time on this before X-Plane 11 is final.
From distance:
http://jardesign.org/forum/img/m/2599/t/p1bbls8cmu155p1g981c8t1cm91md63.jpg
Zoomed in:
http://jardesign.org/forum/img/m/2599/t/p1bbls8p1m15mrf92nva9dk1a045.jpg
275
a) it's crazy fast
Could be interesting to see your log.txt file from x-plane root folder!
