Topic: [old] GHDeluxe v.240317
This is Ground Handling Deluxe plugin by JARDesign v.240317 distributive (Win 7/8, MAC OS 64 bit)
http://jardesign.org/forum/img/m/22/t/p1a9kuc5823gthmbaomic1t9c3.jpg
What new:
+ X-Plane 11 compatible
+ add small stairway
+ add/rework sets for 25 most popular X-Plane aircrafts
Download link http://jardesign.org/gndserv/download/GHD_240317.zip
     1. if need - Save your custom sets from ..X-PLANE/Resources/plugins/GndHandling/Sets/Custom/
     2. save your key.reg file from ..X-PLANE/Resources/plugins/GndHandling/
     3. be sure, that you use X-Plane 10.42+ or 11.00
     4. delete old «GndHandling» from ../X-PLANE/Resources/plugins/
     5. copy unzipped new «GndHandling» folder to ../X-PLANE/Resources/plugins/ folder
- If you have key.reg file from prev version
     6. Paste your saved key.reg file to ..X-PLANE/Resources/plugins/GndHandling/
     7. Paste your saved custom sets to ..X-PLANE/Resources/plugins/GndHandling/Sets/Custom/
     8. Your plugin is always registred
- If you perform New installation
     6. start X-Plane 64 bit and load default Boeing 747
     7. Use X-Plane menu and select the Plugins->Ground Handling->Registration menu and enter your email and the serial key. Next press the SEND button and please check your e-mail. within 1 hr. You should get activation code must be entered in the 'code' field and press CONFIRM. Your application must work well now. If necessary to reinstall, please use the same e-mail and serial number.
     8. activation works well with both MAC/WIN 64 bit
http://jardesign.org/forum/img/m/22/t/p1a9kudbuikvo1b5o1f911i2m1p3u7.jpg
If you want post own liveries for GHD, you may use www.simliveries.com
Re: [old] GHDeluxe v.240317
Thank you for the update
Thank you for using!
Thanks for the update.
Many thanks on this update
Updated!
Can't fly without it...  on the ground I mean...  smile
8 (edited by Maurizio70 2017-06-02 23:59:42)
Installed and does not work ! sad
Remedies?thx!
