Topic: The 3D viewing angle MCDU not allow to see fully what is written
The 3D viewing angle MCDU not allow to see fully what is written in the bottom line of insertion
It is not easy to see the correspondence between the dash of the side key "-" and its text in the MCDU 3D
Re: The 3D viewing angle MCDU not allow to see fully what is written
Easiest solution is to move the viewpoint and then use ctrl+numpad to save the view. To make the text line up with the LSKs perfectly, you may need to move the viewpoint toward the nose of the plane as you look down.
