Skip to forum content
JARDesign Group Board
simpilots/beta-testers/developers forums
Active topics Unanswered topics
Pages Previous 1 … 17 18 19
You must login or register to post a reply
RSS topic feed
Posts: 451 to 453 of 453
J.A.Romanov wrote:About nonworked flightplans - please read Error message at MCDU and lool into log.txt to understand what leg was wrong.
I tried but to no avail.
FP was:
SCEL SID DGO DCT 32S080W 30S090W 26S100W 22S110W 16S120W 06S130W 00N136W DCT WIBIG DCT CAMOS DCT ITO DCT LNY STAR PHNL
Response: CO-RTE ERROR. CHECK LOG
LOG:
[SASL INFO] "mcdu_fpln" --> Set active WPT to SCEL for DetectActualWaypoint reason
[SASL INFO] "mcdu_fpln" Error - UNKNOWN POINT TYPE: 32S080W
[SASL INFO] "mcdu_fpln" CO-ROUTE error occur: ..insert 32S080W
[SASL INFO] "mcdu_fpln" --> Set active WPT to DGO for APT_DEP/DEP_RWY reason
[SASL INFO] "bbox"
[SASL INFO] "bbox" >>> zulu 19:34:8
[SASL INFO] "bbox" baro alt=1678 / rad alt=1
[SASL INFO] "bbox" air spd=-5 / gnd spd=0 / mach=0
[SASL INFO] "bbox" GW=140732 / FOB=16447 / CG=26
[SASL INFO] "bbox" new icao fpln = SCEL SID DGO DCT 32S080W 30S090W 26S100W 22S110W 16S120W 06S130W 00N136W DCT WIBIG DCT CAMOS DCT ITO DCT LNY STAR PHNL
[SASL INFO] "bbox" new fpln full = 1 SCEL (APT) >>> 2 DGO (VOR) >>> 3 DISC (DISC) >>> 4 PHNL (APT) >>> DIST=5966.8718
[SASL INFO] "mcdu_fpln" --> Switch active WPT from SCEL to DGO by internal FMS
[SASL INFO] "bbox" active wpt = 2 DGO
This does not tell me anything special. It found an unknown point type: 32S080W But the AIRAC is 1704 in the plane's FMC and in the PFPX which works from the same AIRAC. So, what should I do?
Yoss wrote:J.A.Romanov wrote:About nonworked flightplans - please read Error message at MCDU and lool into log.txt to understand what leg was wrong.
FP was:
LOG:
[SASL INFO] "bbox"
Tried to CLR the points, so I wanted to enter the FP manually. I can't delete DGO. And now I received an error msg saying: WARNING: a330 systems (SASL) plugin error occur. - Please contact support.jardesign.with log.txt file!
So, I attach the log to this post.
- J.A.Romanov
- Admin
- Offline
So.. after a long-long way we jump to release candidate stage here http://jardesign.org/forum/viewtopic.php?id=2907
As you know may be - this is not the end, but just begin, as usual.
I want to say Thank You for all pilots who take part in this long beta-test trip. I read 100% of your issues, sure. I love you!
Not all issues done, but a lot of.. and we will continue..
Please read a FAQ before you post a bug
http://support.jardesign.org
