1 (edited by juanra100 2016-12-04 16:31:43)
Topic: Not connect with Center
Hello everyone
I can not get the ATC to contact CENTER.
I enter the flight planner.
For example starting LEBL and arrival LENL.
The atc does all the steps correctly but when in the air contact APPROACH, which tells me to climb to the cruising height, but there is no more communication, it does not tell me to contact CENTER.
My airplane is embraer 175 by xkrafts
Xplane 10.51
Airpor BCN Dai Media
What I do wrong
Thank you very much
Re: Not connect with Center
juanra100 wrote:
Hello everyone
Xplane 10.51
What I do wrong
Thank you very much
After reaching your cruise level you must contact ATC yourself when you approach TOD ...then ATC will tell you to contact center ...
3 (edited by juanra100 2016-12-04 19:51:21)
Thank you JCDP
Now if I have been able to contact Center,
But it does not direct me with the headings that I have to take towards my destiny.
Just tell me the destination landing to land and nothing else
And I just takeoff and I'm 900 km  big_smile
4 (edited by jcdp 2016-12-05 18:49:55)
juanra100 wrote:
Thank you JCDP
When you reach the cruise level you are supposed to follow your flight plan .... (do not expect anything from ATC for that, it is not their job ).
And when you reach the Top Of Descent ( the one you have calculated or the one given by FMS of JAR A320/A330 ...) ATC will give you info for final approach  but you still have to follow your FP . (you can choose landing RW if the proposed one does not look convenient for you)
Thank you jcdp
