Topic: SOME HELP PLEASE!!!!
Not sure if i should post this here but did not know were else to post my problem
I have installed X-LIFE and after running X-PLANE 10 i got the License window and clicked Agree
When i run x-plane 10 i check the plugins menu and can see the X-LIFE plugin but when i click the X-LIFE
in the plugins menu there is nothing to choose Traffic ON/OFF Flight Plan Settings is not there.
X-LIFE in X-PLANE plugins is empty
I have downloaded an approved airport to use with X-LIFE but again the X-FLIGHT tab in the X-PLANE plugins menu is empty.
The plugins i have in the X-PLANE menu is PluginAdmin X-LIFE and XPUIPC
But again the X-LIFE is empty
Please note when i start X-PLANE sim i am on the runway ready for take off. could this cause the problem? Do i need to start the sim with the plane at the gate?
If you can please help i will thank you
