Topic: New XL version still some airports are not compatible
As for the previous versions of X-Life even the new one there are some airports which are not working.
I do have at least 3 different APTs (LECL, LIEE, LIMJ) which always give me the darn MessageRed error in XP log:
XL: 0 : OpenSceneryXpath find: /X-Plane 10/Custom Scenery/OpenSceneryX/
XL: 454 : MessageWhite: LELC airport is not X-Life verified! Please use menu and check verified airports Map!
0:08:51.610 I/ATC: Removing p=1 (N01XP) from Active Queue
XL: 454 : JARDesign plugin:X-Plane 10/Resources/plugins/X-Life/Metar/LELC.TXT file updated.
XL: 635 : MessageRed: Please turn On traffic before
XL: 636 : MessageRed: Please turn On traffic before
And naturally no way to create ICAO.txt files since gate editor want start.
Too bad.
Re: New XL version still some airports are not compatible
Silly question.
Do you have custom scenery for these airports?
AFAIK if in the custom scenery you don't have the
../Earth nav data/apt.dat
file, x-life wont run.
I have tried even with an on-line Skype session with the developer everything possible. He took notes of this problem but non fix yet.
Tried with custom scenery, XP Gateway scenery, no scenery (i.e. like using default XP file), XL does not load with this airport I did have developed file sets: LIEE, LIMJ, LELC.  Any possible situation: one taxi route one stand, complete final files, and any possible combination in between. Small airports naturally so easy to make changes.
LMJ I did not developed myself but used one posted by SirTheOne (who have already risen the problem months ago).
The darn "MessageRed: Please turn On traffic before" will come up in the XP log file.
