1 (edited by laohu314 2016-08-06 21:47:09)
Topic: KFMY (Page Field), KPGD (Punta Gorda) and KVNC (Venice Municipal)
Here is a first stab at the three airfields. I have monitored traffic and it works pretty well. ATC will not work as they are not "verified".
The ramps starts are also moved and I have added a few here and there. So  you may want to replace the ramp starts in the respective apt.dat files (the ones that came with the scenery) with the ones from the .dat files provided here. If you don't know how to do that send me a PM.
Static aircraft, where present, are still there. A quick fix is to "hide" them, using WED. Again, if you don't know how to do that, send me a PM.
The ideal fix is to create a scenery file (dsm) in WED with exclusions over the static aircraft and load that scenery before the actual airport scenery. I may or may not get around to doing those.
One or more of the sceneries come with ATC Routes that are NOT compatible with Xlife, so if you want to use the ones from this post you need to remove them from the original scenery using WED. If you don't know how to do that send me a PM.
Disclaimer:
No guarantees that they will work for you. If you see issues send me a PM but don't go on a rant in the forum.
Page Field
http://jardesign.org/forum/img/m/1944/t/p1apgt1ksp1ujn1f11v2a1tgf1pci3.png
http://forums.x-plane.org/index.php?/fi … s-florida/
Punta Gorda
http://jardesign.org/forum/img/m/1944/t/p1apgt2ts4g626flvgi8v38ib.jpg
http://forums.x-plane.org/index.php?/fi … a-airport/
Venice
http://jardesign.org/forum/img/m/1944/t/p1apgt3h6s1h4210d71loh1t28392g.png
Attachment icon KVNC.txt 867 b, 235 downloads since 2016-08-06
Re: KFMY (Page Field), KPGD (Punta Gorda) and KVNC (Venice Municipal)
Thank you so much for doing these airports for the aviation students!  I sincerely appreciate it.
No problem! Hope they, and you, have fun!
Please let me know if you find any issues. Happy to try to correct.
I would like to request these airports be verified from X-Life please.
Thanks for your consideration.
