karterilla wrote:LFOB Beauvais file set.
Reworked scenery included based on this:
http://forums.x-plane.org/index.php?/fi … e-airport/
Not having good aerodrome charts it is not perfect.
Need to be tested had no time to do it myself.
Also scenery should be reworked to avoid landing on short RW 04/22 by heavy stuff. Otherwise should be disabled via the XL tools.
A good question would be if X-Life take care of choosing the correct RW depending on aircraft in use: I do not know.
Thank you for this attempt .
I am going to test it very soon.
Ps: I had attached the only LFOB Airport chart found (I do not know if you have seen it ...may be it is not so detailed as required .)
edit:
Nice flight LFOB-LFBO . Everything was fine
