1 (edited by karterilla 2016-08-10 16:10:37)
Topic: 5 Greek APTs: LGAL, LGKC, LGKN and LGNX + LGSM
Added LGSM Samos.
These are file sets for 5 small, mostly islands, Greek airports.
Based but one (tag) on gateway scenery reworked. Only 3D.
Scenery reworked packages included.
tdg LGKC scenery need libraries not included. Link page original scenery:
http://forums.x-plane.org/index.php?/fi … rt-greece/
LGAL Alexandroupoli
LGKC Kithira
LGKN Kefalonia
LGNX Naxos
LGSM Samos (based on XP GW scenery)
These airport usually even in charts has no stands/routes. So based on satellite views I did put stands and create fake routes.
Being so small was not a problem.
Please test them.
2 (edited by jcdp 2016-08-01 07:12:38)
Re: 5 Greek APTs: LGAL, LGKC, LGKN and LGNX + LGSM
Thanks for sharing all your X-life airports . they work quite well .
May I ask you to to do a french one : LFOB (Beauvais Airport ) the one used by low cost companies (Raynair, Easyjet )
Thank you so much!!!! Can you make also Samos LGSM? Thank you in advance!!
http://forums.x-plane.org/index.php?/fi … land-v864/
Added based on XP GW.
Tested.  But re-test.
