Topic: 2 Greek APTs: LGMK Mykonos and LGSR Santorini
Two X-Life file sets for LGMK Mykonos and LGSR Santorini airports.
Scenery packages included (modded number of stand position etc.) but for LGSR follow instruction below.
Original sceneries:
http://forums.x-plane.org/index.php?/fi … os-greece/
http://forums.x-plane.org/index.php?/fi … santorini/
For LGSR.
You have to replace the original developer scenery folder with the one included.
Read carefully all the instructions on the scenery page since you need to install a 2 folders set in XP "Custom Scenery" and also download and replace the "terrain" folder located inside "zz_GR_+36+...." folder.
If you do not follow the original developer instruction you will see only the runaways.
Please test them.
