1 (edited by karterilla 2016-07-21 04:44:40)
Topic: 8 Greek APTs: LGIR, LGKO, LGKR, LGSA, LGZA and LGTS + LGPR + LGSK
Here 6 greek airports for X-Life.
LGIR Iraklion
LGKO Kos
LGKR Kerkira
LGSA Suda
LGTS Thessaloniki
LGZA Zakinthos
All use XP gateway scenery packages (some modified, more gates/stands, different planes locations, etc.) and they are included.
LGTS uses now only 16/34 runway (satellite view show the old 10/28 almost bombed with holes and missing parts).
Please test.
Added as request LGPR RODOS.
link to the scenery:
http://forums.x-plane.org/index.php?/fi … ras-xp864/
Also added LGSK Skiathos from XP gateway.
Re: 8 Greek APTs: LGIR, LGKO, LGKR, LGSA, LGZA and LGTS + LGPR + LGSK
Thank you very much for these Greek airports!!!! Could you make also the LGRP? Thank you in advance!!!!
Hi would like to do it but there is no a free (good) scenery.
The only one I di have found is this:
http://secure.simmarket.com/greek-airpo … e-10.phtml
But it is not free.
If you have a link to something that can be downloaded for free post it.
It is not perfect, but the only free I found. I hope you can make something out of it. Thank you very much.
Added LGRP.
Test it.
Thank you so much for your time and effort!!!
Could you possibly make the LGSR and LGMK also? Thank you in advance!!!
http://forums.x-plane.org/index.php?/fi … os-greece/
http://forums.x-plane.org/index.php?/fi … santorini/
Posted both in a new thread.
But LGSR can have problem due to old scenery and not real standard scenery config...
Test them.
There is another one LGRP from tdg on x-plane.org is it possible to somone make this as well? thanks.
I'm using XP11 and X-Life is not working at LGKR with this files. Here is the link to the XP11 Scenery:
http://forums.x-plane.org/index.php?/fi … orfu-xp11/
Would be great if someone could help out to fix it.
Thanks Fabian
Here are also some other airports which need small fixes in the files above:
http://forums.x-plane.org/index.php?/fi … -diagoras/
http://forums.x-plane.org/index.php?/fi … eece-xp11/
http://forums.x-plane.org/index.php?/fi … rt-greece/
