Topic: Delete From X-Plane
I installed on my computer (specs below) and I need to uninstall the program.  It has slowed me down to 5 FPS.  I want to make sure I do this properly so I don't cause x-plane to be unstable.  I have disabled the plug-in but it is taking forever to load X-Plane.
Is it as easy as removing the folder from the plug-in folder or are there other files that need to be removed?
Specs:
Windows 10 64 bit
i7 5820k CPU
16.0 GB Memory
NVidia 970 4 GB
2 TB Hard Drive
Re: Delete From X-Plane
Are you sure it's GHD causing this? post your log txt so we can see
Theoretically you only need to remove the folder...but I also don't think that the GND Handling plugin is causing this...what frames where you experiencing before? are those fps issues also during flight?
Greetings Ben
