Topic: UUDD - Moscow Domodedovo Intl RUSSIA
For freeware (5 star) UUDD - Moscow Domodedovo International airport by JarDesign.
http://forums.x-plane.org/index.php?/fi … ow-russia/
http://jardesign.org/forum/img/m/2234/t/p1ako613tpgcf129k18ie1umi1fc43.jpg
http://jardesign.org/forum/img/m/2234/t/p1ako613tp1fv61s2q1hs41q111vnu4.jpg
When you start FMCar and/or X-Life next time, UUDD files will be autodownloaded to your /Airports/ folder (for version without statics) .
Also, a real frequencies of airport are included to UUDD.txt
This airport exists in two versions. The first version with static aircrafts, the second version without them. I include two version of UUDD.txt files:
- UUDD.txt.NST - for no static version;
- UUDD.txt.ST - for static version.
Just choose what you want and delete the extension in name of the file till '.txt', then copy to the plugin 'Airport' folder.
