1 (edited by vatech 2016-05-24 16:09:55)
Topic: KDFW- Dallas Fort Worth USA {2 VERSIONS}
by Tom Curtis for payware (5 star) KDFW- Dallas Fort Worth - American's Country by Tom Curtis
http://store.x-plane.org/KDFW-Dallas-Fo … p_476.html
http://jardesign.org/forum/img/m/2234/t/p1ajh1ml2h130bjtb1ss6bco1alk3.jpg
http://jardesign.org/forum/img/m/2234/t/p1ajh1mpsv8kn13stc72don16bu5.jpg
When you start FMCar and/or X-Life next time, KDFW files will be autodownloaded to your /Airports/ folder.
Also, a real frequencies of airport are included to KDFW.txt
PLEASE NOTE !!! That files on server for KDFW will be changed
from freeware version (IN NEXT POST BELOW) for this payware version
from Scenery4XP (Tom Curtis). If you wish to use payware version with X-Life, but before used freware version,
you must change the data files for KDFW manually, because X-Life don't overwrites files automaticaly.
After discussions, static aircrafts was not excluded. Traffic appears on places, what is free from static aircrafts.
2 (edited by vatech 2016-05-24 16:04:32)
Re: KDFW- Dallas Fort Worth USA {2 VERSIONS}
For freeware (5 star) KDFW Dallas Fort Worth.
http://jardesign.org/forum/img/m/2234/t/p1aektq6tv7mtvcolvn1bin19pa3.jpg
http://jardesign.org/forum/img/m/2234/t/p1aektqdko1qqk143r1ufclg91pch5.jpg
As usual I added the 'KDFW - Dallas Fort Worth Nostatic' scenery.
To remove the existing static aircrafts where it need, please install "KDFW - Dallas Fort Worth Nostatic" scenery to you 'custom scenery' folder. Don't forget what "nostatic scenery" must be located higher then 'KDFW - Dallas Fort Worth' scenery in the scenery_packs.ini file. Please don't forget to follow this rule.
