Topic: LEMH - Aeropuerto de Menorca
These are the ATC Routes for the freeware LEMH
http://forums.x-plane.org/index.php?/fi … rca-spain/
The LEMH.dat has all the available stands and gates.
The LEMH.txt.static has the stands and gates with static objects set to Static. (remove the .static for usage)
The LEMH.txt has all stands and gates set to active. (use only with "AAA_LEMH_No_Static")
The AAA_LEMH_No_Static.zip contains the files for removing all but one static aircraft and some stairs and equipment. (unpack the folder "AAA_LEMH_No_Static"into your "custom scenery" folder and make sure that it is located ABOVE the actual LEMH scenery inside the scenery_packs.ini)
Please note that this is my very first attempt on creating a Taxi Route. It works just fine for me but i would be very grateful if someone could give it a try and let me know if i forgot something or made any mistakes.
Cheers
Chris
