1 (edited by vatech 2016-05-16 12:33:51)
Topic: PAJN - Juneau International Airport Alaska
For freeware (5 star) PAJN - Juneau Intl Airport
http://forums.x-plane.org/index.php?/fi … rnational/
http://jardesign.org/forum/img/m/2234/t/p1aisnrusg1hqcmclmp3vtddd3.jpg
http://jardesign.org/forum/img/m/2234/t/p1aisns4q9t461k54ct8mmv1lfu5.jpg
When you start FMCar and/or X-Life next time, PAJN files will be autodownloaded to your /Airports/ folder.
Also, a real frequencies of airport are included to PAJN.txt
To remove the existing static aircrafts, just unpack the 'PAJN - Juneau International Nostatic.zip' archive to you 'custom scenery' folder. Don't forget what "PAJN - Juneau International Nostatic" must be located higher then PAJN main scenery in the 'scenery_packs.ini' file. Please don't forget about this.
ATTENTION
For all users who have HD Mesh V3 by AllPilot Installed. A conflict between X-Life and HD Mesh V3 exist in this airport, as result, traffic airplanes can not landing properly to runway with this mesh. So you decide that is you need, mesh or traffic. As for me, I deleted the mesh.
Attachment icon PAJN - Juneau International Nostatic.zip 1.61 kb, 393 downloads since 2016-05-16
Re: PAJN - Juneau International Airport Alaska
Did you see my post on you KFLL ...
3 (edited by vatech 2016-05-16 14:39:57)
Yes I see, but I don't understand you problem. Tell me briefly what you want? If about runways in KFLL, then I have already said, that this scenery from nimbus was created before reconstruction of airport and in what time was three runways. After reconstruction of KFLL runway 13/31 was deleted, and 09L/27R was changed to 10L/28R, 09R/27L to 10R/28L so you see it in latest data bases. Just select the SID for 09L like 10L for example.
4 (edited by captbullett 2016-05-17 03:25:14)
I had to go to VA early so, I am trying to work through the issue I now do believe the issue is in the MCDU, so how do we proceed to work on fixing the issue of having the other runways display in the MCDU from nimbus in the JAR A320Ne.
This is how I am through I am, I  posted the issue here to see if it was something in conflict here not to give you a hard time but to make sure we do not have an issue down the road.
Then for the last, did I not download the right data base is this what I did wrong?
No I did not do a thing wrong after checking what is this OH, 09 27L IN THE KFLL.dat txt FILE THIS WAS THIS WAS NOT FIXED !
BUT YOU DID NOT LISTEN TO ME ! THIS WAS A FRESH DOWNLOAD ! FROM YOUR WORK ABOVE OR IN THE KFLL WEBSITE !
1204 departure 09R,27L
1204 arrival 09R,27L
1204 ils 09R,27L
1202 273 274 twoway runway 09R/27L
1204 ils 09R,27L
1202 274 275 twoway runway 09R/27L
1204 ils 09R,27L
1202 275 276 twoway runway 09R/27L
1204 ils 09R,27L
1202 276 277 twoway runway 09R/27L
