Topic: CYVR - Vancouver International Airport Canada
For freeware (5 star) CYVR - Vancouver Intl Airport
http://jardesign.org/forum/img/m/2234/t/p1aij69aijmpt1g62g923sj1fuk3.jpg
http://jardesign.org/forum/img/m/2234/t/p1aij69j6c3v3nt216ur1vcr1lh45.jpg
When you start FMCar and/or X-Life next time, CYVR files will be autodownloaded to your /Airports/ folder.
Also, a real frequencies of airport are included to CYVR.txt
Please note, that files on server for CYVR will be changed from previous freeware version from "X-Plane Scenery Gateway" to current freeware version. If you wish to use current version with X-Life, but used version from "X-Plane Scenery Gateway" before, you must change the data files for CYVR manually, because X-Life don't overwrites files automaticaly.
If you wish to remove the existing static aircrafts, just unpack the 'CYVR - Vancouver International Nostatic.zip' archive to you 'custom scenery' folder. Don't forget what "CYVR - Vancouver International Nostatic" must be located higher then CYVR main scenery in the 'scenery_packs.ini' file. Please don't forget about this.
Attachment icon CYVR - Vancouver International Nostatic.zip 2.18 kb, 532 downloads since 2016-05-12
