Topic: KILM - Wilmington International Airport USA
For payware (5 star) KILM - Wilmington International Airport by Drawbridge Designs.
http://store.x-plane.org/KILM--Wilmingt … p_247.html
When you start FMCar and/or X-Life next time, KILM files will be autodownloaded to your /Airports/ folder.
Also, a real frequencies of airport are included to KILM.txt
As usual I added the 'KILM - Wilmington International Airport Nostatic' scenery.
To remove the existing static aircrafts where it need, please unpack KILM - Wilmington International Airport Nostatic.zip archive to you 'custom scenery' folder. Don't forget what "nostatic" scenery must be located higher then KILM main scenery in the scenery_packs.ini file. Please don't forget to follow this rule.
