1 (edited by cessnarox 2016-04-23 19:44:22)
Topic: Ground Handling Deluxe SET for IXEG 737-300 1.0.0
http://jardesign.org/forum/img/m/1639/t/p1ah2ad16h1p221n48kfk1j6iq513.jpg
http://jardesign.org/forum/img/m/1639/t/p1ah2ad16ht5ck8t1oft4vav0r4.jpg
http://jardesign.org/forum/img/m/1639/t/p1ah2ad16hgelj9b12mvf3c1u4e5.jpg
http://jardesign.org/forum/img/m/1639/t/p1ah2ad16hp321ef31do67rgr06.jpg
The stairs are a little too big for the plane, hence why the front truck enters the plane a little bit.
For accuracy DO NOT use the Air Conditioning Unit at the same time at the front catering and loader trucks. IXEG seems to have placed it in the wrong location according to the diagrams i have found by Boeing, you can see this in the screenshots.
IF you would like a "gate-friendly" version, go to the plugins menu, select Build Aircraft Set. Press DEL next to Staircase-1, Staircase-2, and neoplan-1. Exit out of that menu, and you may use the plugin as normal and it will be "gate-friendly".
I have not put in a GHD gpu because it is not compatible with the 733, but i have put cones around the IXEG GPU.
The doors do not open on the 733 yet, but when the update comes out this set should work fine with open doors, if not i will update it.
When you click drive away the trucks do not park perfectly "neat", but that doesn't happen in real life so much either tongue
Let me know if you see anything wrong and i will try and fix it!
Like me on Facebook for updates, make requests, WIP, etc!
https://www.facebook.com/cessnaroxliveries
Re: Ground Handling Deluxe SET for IXEG 737-300 1.0.0
Great. Thanks!
Thanks a lot!!!
Many thanks!
I've read in the X-Pilot forums that there where some sound compatibility problems with GroundHandling and IXEG 737. Have you experienced any problems or is it solved?
Good work. As for the stairs, you can extend the platform, therefore the truck doesn't need to crash into the plane. Only thing left, the stairs are too high and the hydraulic rams are "broken". But there is nothing you can do about that.
Great work! Thanks for sharing
