Topic: LEMG - Málaga–Costa del Sol Airport Spain
For freeware (5 star) LEMG - Málaga–Costa del Sol Airport
http://forums.x-plane.org/index.php?/fi … a-airport/
When you start FMCar and/or X-Life next time, LEMG files will be autodownloaded to your /Airports/ folder.
Also, a real frequencies of airport are included to LEMG.txt
If you wish to remove the existing static aircrafts (and I recommends to do this), please install "LEMG - Malaga Costa Del Sol Airport Nostatic" scenery to you 'custom scenery' folder. Don't forget what "nostatic scenery" must be located above the main LEMG airport scenery in the scenery_packs.ini file. Please don't forget to follow this rule.
