Topic: MPTO - Tocumen International Panama
By Ivan Vetrov for payware (5 star) MPTO - Tocumen intl airport by Nimbus Simulation.
http://store.x-plane.org/Tocumen-Intern … p_224.html
When you start FMCar and/or X-Life next time, MPTO files will be autodownloaded to your /Airports/ folder.
Also, a real frequencies of airport are included to MPTO.txt
The 'MPTO - Panama Tocumen Intl' by Nimbus Simulation includes static aircrafts on parkings and gates, but, due to the arrangement of the objects in the scenery we can't remove them all (only partially), and we have no rights for adding the changes, or editing files of the scenery. We requested to Nimbus Simulation create a additional scenery without static aircrafts, but in current time, the only one solution exists, it's use the stands and gates without statics. However we delete some part static aircraft, what do not affects to other scenery objects (MPTO - Panama Tocumen Intl Nostatic.zip ) and created a data files that includes all gates (if in future will be created additional scenery without statics), and noted the places with static aircrafts in Gate Editor. Also don't forget what "MPTO - Panama Tocumen Intl Nostatic" must be located higher then MPTO main scenery in the scenery_packs.ini file. Please remember this.
