1 (edited by vatech 2016-04-16 10:40:15)
Topic: KJFK - John F. Kennedy intl USA
For payware (5 star) by Drzewiecki Design New York Airports XP
Link1: http://store.x-plane.org/New-York-Airpo … p_355.html
Link2: http://www.drzewiecki-design.net/prodNYAirports_XP.htm
When you start FMCar and/or X-Life next time, KJFK files will be autodownloaded to your /Airports/ folder.
Also, a real frequencies of airport are included to KJFK.txt
1. Static aircraft in the scenery:
Two static aircrafts are present In this scenery, but it don't interfere to X-Life.
2. Couple important words, about "FM Car" in this scenery.
Due to the "New York Airports XP" scenery includes seven airports inside, some restriction are present for use the "Follow me car" with this scenery, if exactly restrictions for using FMCar Like stand alone plugin. Data file of this scenery contains information about  all seven ports, so that no opportunity to display all of airports on FMCar map, and in the same time to handle with data of all airports in this scenery, thatswhy the plugin did not working. However the owners of the "X-Life Deluxe " version, always can request the Follow me car from ATC menu of X-Life in Ground control section. ATC gives route to FM Car, it appears and will accompanies you to necessary place.
Not to be unfounded I attached the screenshot from my X-Plane with FM car in KJFK.
http://jardesign.org/forum/img/m/2234/t/p1agfabnneo7g1639kba1cbcor83.jpg
Sorry for inconvinience and thank you.
