Topic: Copilot x TS321 installation problem
I recently purchased Copilot for TS A321, I followed the instructions in the manual (Copilot Setup from menu, reloaded plane from Developer, restarted X-Plane) The copilot menu appeared with the various options, but no Copilot appeared . Below is the excerpt from the XPlane flie log. What must I do??
JD COPILOT Plugin: 0 SEC TFT Version: v.090122
Error: Non-aircraft plugin copilot_main/win.xpl failed to access the aircraft menu.
Loaded: M:\X-Plane 12/Resources/plugins/copilot_main/win.xpl (jardesign.copilot).
Loaded: M:\X-Plane 12/Resources/plugins/copilot_speech/win.xpl (jardesign.copilot.speech).
i can see all de command in Toliss menù, I can read de overlay test and ear Linda, but I cant see her.
SOLVED!!!
