Topic: Editing Sets - Using Text Edit makes set disappear. How to edit?
I created a custom set for the FF B777, deleting a couple items. However, I want to change a catering unit to a stairs. I opened the custom set file in BBEdit as a text file, changed the item to Stairway, saved. However, when I then reload that set, it's blank.
Is it not possible to edit a custom set in a text editor? If so, what's the trick?
Re: Editing Sets - Using Text Edit makes set disappear. How to edit?
I may have figured it out. This time I removed the .set appendage, then opened it in BBEdit, made my changes, saved, then added the .set again. Seems to be working.
