1 (edited by ernst.wagner 2023-01-19 16:24:10)
Topic: [Solved] Linda sitting outside ?
I installed the trial version of CoPilot for Zibo737 according to the manual correctly (hopefully ;-) ... BUT ... Linda is sitting outside like a hood ornament.
http://jardesign.org/forum/img/m/13775/t/p1gmgk40sq11ba1u0o30e1o971gcj3.jpg
Why?
I'm running Windows 11 pro, X-Plane 11.55r2 Vulcan and ZIBO 3.54.17
Thank You for Your help!
Ernst
Re: [Solved] Linda sitting outside ?
that mean copilot plugin look like not running. We may check this via Log file. Please send me (attach) a Log.txt file from X-Plane folder saved just after start X-Plane and load aircraft - I will check and inform you.
SOLVED
I did a clean reinstall of the ZIBO B737-800 and the CoPilot for Zibo737, and it worked.
Going furthermore step by step I recognised, that the plugin doesn't like it, then I deactivate the "_4k"-version of the ZIBO B737-800. So i activated the "_4k"-version again, and everything works well.
Now I have to learn to deal with the situation, that Linda is sitting next to me and talks to me ;-)
Happy Landings
Ernst
