Topic: GROUND HANDLING DELUXE XP12_130922 -NO VEHICLES
Evening all,
Is anyone else having an issue with GHD for Xplane 12 RC3?
When I select an aircraft, Toliss, Zibo and LR planes, I go to plugins and select GHD Control Panel and then request the vehicles i want.  The thing is, no vehicles arrive.
Any suggestions please?
All the best
Steve
Re: GROUND HANDLING DELUXE XP12_130922 -NO VEHICLES
Please check your parking brake On before call GHD
Any Solution available for SSG B748?
The Parkbrake doesn't work in this A/C.
It can't be turned on. Even with the Brake Lever in the Cockpit or via Dataref. No Function.
Therefore GHD Vehicles disappear when trying to drive them up.
X-Plane since V10
that is mean this acf may have a problem with pushback, as example. So, trying to find SSG contacts to clear this.
So.. when you are Cold and Dark - no pressure and no brake you have. As result - no set will come.
Solution: BAT On, APU On, AUX Hydraulic pump On - you will get Park Brake and set, for sure.
