1 (edited by marespi 2022-09-13 09:12:08)
Topic: Alternate fuel truck
Would it be possible to have an alternate fuel truck, hydrant/pump dispenser type?
On larger airport, at jetways, hydrant are often used.
You could select which truck to use (hydrant or reservoir) based on ramp type: At jetways, use hydrant, at remore parking, use reservoir truck. Also, for larger aicraft, consider using larger fuel truck.
Thank you.
Pierre
Re: Alternate fuel truck
Thank you.
Pierre
If you ask is it possible to get it from exist plugin - no, sorry.
If you ask about possible to create yourself - yes. You may contact me via Skype j.a.romanov for this.
