Topic: Overspeed at cruise altitude
Is there a problem flying at cruise altitude?  Flew today and the autopilot kept tripping off due to an overspeed issue.  Throttles were at climb detent and autothrust was on.
CI was 107 and my managed speed per the perf page was set to 300/.82.
Consistently, I'd overspeed and have to manually slow down because the plane would pitch up massively to try to bleed it off.
Bug?
Re: Overspeed at cruise altitude
Bug?
The best way to know this - read Log.txt file (from root X-Plane folder) saved just after issue happen. "black box" info there may understand what really happen. You may attach it here or send to my Skype j.a.romanov
Thank you.  I'm rerunning the same flight plan at the moment and this time its not having any problems.  I'll keep plugging at it and if/when it happens again I'll make sure to save the log.txt file and send it your way.
Appreciate the support.  Have a good day!
Thank you!
