201 (edited by ilankrt 2016-07-14 12:08:24)
I know, 10.5b5 is a BETA but it's pretty stable and works with the A330 so I'm surprised by this. Eugeny may not want to look into this because it is a BETA but I thought I'd report anyway, maybe it helps.
iMac 27” (late 2015), Core i7, OSX 10.11.4, 32GB RAM, AMD Radeon R9 M395X 4096 MB VRAM
Saitek X52,  Radio, Switch and Multi Panel, TM Cougar, XP v10.50b5, JD A220neo v2.6r2, XL v1.1r3, FM v2.4r1, SMP3, RWC, FWL, PythonInterface, NOAA weather, XChecklist
As previously reported, the autopilot takes the AC to the first waypoint but then doesn't engage any course changes.
I hand-flew a couple of waypoints and when I re-engaged the AP it correctly flew the route - until below FL100 on Approach, when it stopped changing course again.
So I had to hand-fly final approach and landing which went well (was too busy to interact with ATC so got abandoned).
P r e t t y  s c a r y!
Is anyone more have exact the same, please?
Yesterday I had the same problem during final approach.
First framerate was sinking from 28 fps to 5-7 fps
Then aircraft flew out of a turn although under AP
I flew manually back on course and engaged AP again and the aircraft followed further on AP landing mode
202
captbullet, get the F--- off my back already. I DID POST a log and I DID NOT ask for help. Certainly not you because you are an incompetent troll who can't shut up and stop himself from spreading bullshit.
Check the facts before you crap all over this bulletin
You upset up for nothing. He does not understand and we can not just get rid of him. So he has already transformed X-Life discussions to X-dead and he makes his senseless bla bla on and on ...
203
I know, I should keep my cool...
Working on it
204
Later today I will try a reinstall of Jardesign A320 with 10.50b6, with the hope that maybe a fresh installation will fix the two problems I have experienced:
- LNAV not working
- lit buttons and displays not appearing at night (they appear during the day and with night vision turned on)
205
I can confirm that after a fresh reinstall, the lit buttons now display and the LNAV basically functions. However, I tried to conduct the LOOP8 departure out of KLAX, but that didn't work, it just directed me straight to the first waypoint.
206
You can independently of X-Life ATC program your FMC as you wish.... ATC will return at the transit level...
207
Also I note that my A320 is struggling to keep airspeed at cruise. My throttle is set to THR CLB , which turns into MACH at ALT CRZ. But the throttle remains in the mid-70's, but airspeed drifts down. I have to keep throttle at TOGA or MAN FLEX to get to desired airspeed. Any tips?
208
You're cruising at too-high an altitude for your weight. Start 2000-4000 ft lower then step climb later.
209
-Under no circumstances it is possible to activate auto throttle, whether you click with the finger or with the hand on the SPD knob before or after setting a value(heading/alt settings work after pulling the knob with the hand)
-Plane does not work properly with xSaitek Multipanel, AP button permanently blinking
-Spoilers cannot be extended(although the leverage in the cockpit is moved), not sure if I had set my throttle to idle, may be no bug with the Neo
-Made me smile: If you turn the cabin temp switcher most right, the stewardess complains: its too hot sir. If you turn it most left(so on very cold), she complains as well thats too hot wheras she should say its too cold. Only if the button is in middle position she is satified...
Christian
210
I have install the A320 but i haven,t got the activate code.
211
I have no activate code receive.
212
when you bought your JAR A320, you got a code (in the recept that you paid, mail)
Follow the instructies of activation and you will het another mail with a code.
Check your spam box! It sometimes happen that this mail is in the spam box.
Win 10, XP11
213
According to the MCDU, I am at optimum cruise level. It seems the MCDU is wrong then.
214
It is very frustrating -- I am not fully loaded, I only have about 6000kg of fuel and I am at FL360. The aircraft can't even keep cruising mach. Throttle keeps at about 75% N1 and airspeed drops to below M0.70. I can't do oceanic flights as I can't keep airspeed. There is something wrong with the Autothrottle. No doubt.
215
At what level did you set the Cost Index (CI)? If you use a very low level (< 50) that might prevent the FMGS from setting a high enough cruise speed (not sure about that, though). In any case, set the CI at 90 and see what happens...
I never have this problem with CI > 60
216
First of all, an hour flight + reserve needs nearly 6 T. To climb at this time to FL360 is nonsense !
Think, you are not sitting in a Lamborgini, giving gas and speed up to max.
Second There is Airspeed, Groundspeed and Truespeed, the IAS indicator indicates a lower speed because the more you climb, the less air there is. So even the air flows faster, the global pressure feeling is lower.
So, actually planes are not slower at higher altitudes. They are faster (at least most planes whose flight envelope force them to fly faster when they are higher, otherwise they would stall, because they would have to increase their Angle of Attack too much to counterbalance the lack of air flowing above and under the wings). But when they reach their target Mach speed, their speed will decrease slowly as the outside air temperature is decreasing until end of climb....
217
I just tried to increase altitude from FL370 to FL390, auto throttle actually reduced power and refused to climb even though optimal alt was FL385, had to use V/S mode to climb and it still did not increase engine thrust, also on decent into EGLL tried to enter a hold at BIG computer refused to do it and lost all my waypoints on the ND and could not get them back had to VOR all the way in using standby instruments.
218
Please upload your log.txt and bbox.txt, otherwise it's nearly impossible to help.
219
I do not know whether this is the correct forum.
I have xplane 10.5 (non beta final version) and a320neo JARDesign ver 2.6 r2 on
a Windows 10 machine.
Whenever I try to change a320neo livery, xplane 10.50 crashes. I am able to change
the liveries of other planes.
Also I am unable to see the ground terrain when the TERR ON ND is switched on.
Can any one guide me in these matters please.
220
Hello.
Several problem for me:
- The screen does not indicate weather with NOAA weather
- The tail of the plane did enlightened than the right side
- The boutton ranks 320 does not work
Thank you for your help
221 (edited by kmjkyj0327 2016-08-14 19:55:14)
i already dowload a320neo but what is Reg code?
222
When you open the aircraft put a code for open
223
I have a problem with bss sounds since 2.6r2.
They are not working anymore.
224
Just fixed smile
225
Mczell wrote:
Just fixed smile
remove all plug in and lets BBS
