I've adapted the ATC Taxi Routes for ZBAA from the recommended package on the Gateway.
The stands were not connected and I replaced all the static stands with real ones. If you use the package I recommend to remove the static aircraft with WED to avoid overlapping aircraft (static and XL generated).
https://gateway.x-plane.com/scenery/page/ZBAA
