1 (edited by vatech 2016-04-11 13:04:18)
Topic: KMIA - Miami International USA
For payware (5 star) KMIA - Miami International airport by Nimbus Simulation.
http://store.x-plane.org/KMIA--Miami-In … p_126.html
http://jardesign.org/forum/img/m/2234/t/p1afosnsc1nuk1mij1aq31eiah1i3.jpg
http://jardesign.org/forum/img/m/2234/t/p1afoso2fc6141nebi89168513m25.jpg
When you start FMCar and/or X-Life next time, KMIA files will be autodownloaded to your /Airports/ folder.
Also, a real frequencies of airport are included to KMIA.txt
The 'KMIA - Miami International' by Nimbus Simulation includes static aircrafts on parkings and gates, but, due to the arrangement of the objects in the scenery we can't remove them, and we have no rights for adding the changes, or editing files of the scenery. We requested to Nimbus Simulation create a additional scenery without static aircrafts, but in current time, the only one solution exists, it's use the stands and gates without statics. However we created a data files that includes all gates (if in future will be created additional scenery without statics), and noted the places with static aircrafts in Gate Editor.
Re: KMIA - Miami International USA
I wanted to reach out, and see if you could help me figure out why I can't get XLife to load anything for KMIA. I purchased the Nimbus payware of KMIA and it works in XPlane perfectly, but when starting XLife I get nothing. It loads, but no aircraft, and no flight schedule and nothing at gates. I have KMCO, KFLL, KJAX, and KATL all working perfectly and beautifully with XLife, but for some weird reason KMIA, although shown as supported with the payware from Nimbus, refuses to work.
I know I am missing something, but I have spent hours reworking plugins to get a clean X-Plane to verify it's not another plugin causing the problem. I will attach my LOG file and see if someone can spot what I may be missing.
I even tried the XPlane.org free KMIA but it does not matter what scenery I use, even default X-Plane scenery fails to work for KMIA. It's seems odd to me that it just doesn't want to work when it works beautifully for all other areas around Florida I have utilized.
Thanks for your help, and a wonderful Xlife program. I went back to XLife because World Traffic2.0 was pissing me off.
X2 on the above post
I don't have the Nimbus scenery but have you checked if the apt.dat has ATC Taxi Routes installed as well?  Some payware sceneries do but often the routes are not compliant with XL so need to be removed. Use WED to check.
