Topic: CoPilot Plugin for JD340-500 (X-Plane 11)
http://jardesign.org/forum/img/m/22/t/p1fcgbkbbj1kf71oebdd71t7k3gu3.jpg
The work of the pilots in a modern airliner involves two people. You know. Of course, before, the voice of the f.o. pilot was present, but he did not do anything and did not execute commands, did not listen to you, did not live with you. I really wanted this to change and I am happy that my friends supported me in this matter.
So, this is CoPilot plugin for JD340-500 Airliner
YouTube Demo: https://youtu.be/6u2hQQt8Jxc
REQUIREMENTS:
+ X-Plane 11.41-11.50 flight similator
+ Windows OS (7 .. 10) or MAC OS (Sierra .. Catalina)
+ Microphone or Headset
+ JARDesign JD340-500 Airliner version 1.1+ (not included)
+ For voice input Speech Recognition language should be set to English only (for Windows OS)
LANGUAGE: English
DESCRIPTION:
Her name is Linda. She is well-qualified Airbus A340-500 (TM) F.O./copilot. Main Features:
+ animated 3d CoPilot body
+ can recognize and execute your command
+ can speak with you
+ can read checklists
+ can operate with flight events (based on flight parameters detection)
+ can execute SOP (Normal Procedures)
This product is not refundable, but You can download, install and test the demo version (Manual included):
http://www.jardesign.org/copilotdownload/JD-CPL-345.zip
Demo mode work up to takeoff phase of the flight. If you like the demo version and you prefer to use the full version - you may purchase serial key here:
SIMMARKET: https://secure.simmarket.com/jardesign- … e-11.phtml
X-PLANE.ORG: https://store.x-plane.org/CoPilot-for-J … _1474.html
SUPPORT: www.support.jardesign.org
2 (edited by godmann 2021-08-08 09:26:09)
Re: CoPilot Plugin for JD340-500 (X-Plane 11)
I have opened a ticket.
Hello.
Very nice as always the copilot.
I'm seeing that it has a little bug, after takeoff it starts all the time asta reach the level of cruise TARA mode  set and when it is in cruise is when comienza to perform the procedure of check of takeoff, which in the first place is quite annoying the constant sound, even giving it manually continues with the TARA.
Greetings.
Hello.
Greetings.
Will this work for Toliss a340? Thanks
Hmm.. This depend mostly from You and another users. So, if some users will ask Torsten (Toliss) about AP creation and we will get request from him - we can start to create CoPilot for TL346.
Please count me in for Toliss A340 and Felis 747 copilot +FE as well. Thanks
Hello.
Greetings.
resgeo1@yahoo.gr wrote:
Hello.
Greetings.
am getting this as well. It continues saying TARA mode is set
Hello.
Greetings.
Thanks for report - fixed.
Please take attached file and put it to /plugins/copilot_main/systems/  folder instead of exist one
