126
Re: JD340 v.1.4
In this updated version 1.3, the aircraft will not report the radio altitude before landing. Is this a bug? If it is, please tell me which version I should choose. I really need this feature, thank you!
Re: JD340 v.1.4
Hello JarDesign team, I would like to report a bug - on the TCA quadrant the speed brake is not working and the auto brake is a littlebit buggy. when going from LO to 2 it goes back to disarm.
128
Re: JD340 v.1.4
Are you kidding us. ?? the plane does what it should. Either you cannot operate the machine or you are using it incorrectly. What you are talking about is complete nonsense. or play Fortnite. Simulation is not for you
Re: JD340 v.1.4
Hello.
I get in touch, for the reason I have bought the a345 JD, in all the previous updates, I asked for the serial to paste it and activate it without problem.
Today I am trying to put the update in my holiday home that is another pc and tells me that the license is expired.
I hope you can give me a solution to enjoy my newplane.
I can't find where to put a tiket  for this product.
I do not understand how since day 5 I put this problem and you do not answer, I was very happy with your product, but your support behavior is making me very angry at not being able to fly my new plane.
Answer, please.
130
Re: JD340 v.1.4
IBE1001 wrote:
Hello.
Answer, please.
please www.support.jardesign.org
Re: JD340 v.1.4
Please be sure what you setup TCA as described in manual and you set axis control in settings.
132
Re: JD340 v.1.4
Hi Jardesign Team
Thank you for the new JDA340
Have you plan to develop JDA380?
Adrien (France)
133
Re: JD340 v.1.4
corcondilas wrote:
Hi Jardesign Team
Adrien (France)
Sorry, but no - we plan to update exist products.
134
Re: JD340 v.1.4
the mouse wheel manipulators doesn't work on the 1.3r2
135
Re: JD340 v.1.4
Uuuups.. Sadly only way to fix this - redownload and reinstall whole aircraft version 1.3r2 (look like some files was broken)
136 (edited by jcdp 2021-09-28 17:29:22)
Re: JD340 v.1.4
last version is supposed to be v1.3R2  but last version text still shows v1.3R1 after download from ".org" ...
Re: JD340 v.1.4
Yes, but if more fresh version exist - user get instant notifications about this when start aircraft and link to actual download page.
138
Re: JD340 v.1.4
Hi thanks for your answer    but
Starting x-plane with A340 v1.3r1 did not give me "instant notifications" for a new version 1.3r2 ...nor link for downloading .
Page one of this topic leads to ".org" for download  with version 1.3r1 ...
Using page "for download of all products" gives me same result v 1.3r1 ...
so my question is still does it actually exist a version 1.3r2  with no modification of "version text" file remaining with v1.3r1 ?
The best, if v1.3r2 exists would be to put in your answer the link for downloading .
Thanks in advance.
Re: JD340 v.1.4
Thanks in advance.
You are correct absolutely. Version 1.3r2 not bring instant notification for now. As usual - Firstly - we post info at FB page and our Board. Several days later - we ad info to our server to bring instant notification. This need to make new version info not so wide and allow test release by most active users.
Re: JD340 v.1.4
What bug is flying without following the route,
141 (edited by helloxusen 2021-10-02 10:47:23)
Re: JD340 v.1.4
This route appears
like this
142
Re: JD340 v.1.4
If AP not follow route - There is a big chance what it is some special problem on user side, cause most users have not this problem. The reason may be:
1. An affect of some another installed plugin. There is simple solution in this case to check - load Cessna 172, open X-Plane Menu->Plugins->Plugin Admin to disable ALL plugins, next - load JD320/330. If issue gone - one of your plugin conflict with Airbus FMGS.
2. Problem may come from hardware, from your joystick. Please check - if some of your joystick switch assigned to "Avionics OFF/ON" - it should be stay in ON position when you run JD320/330.
3. Something wrong in settings. To check this faster - please find "Output" folder inside your X-Plane folder and rename it to "OutputOld". Next - run X-Plane. In this case X-Plane will create new and clean "Output" folder with clean settings. Please calibrate your joysticks and check JD320/330 autopilot. If issue gone - some settings was a reason.
143
Re: JD340 v.1.4
The 1.4r2 crashes my Mac to the desktop when I try to load the Plane
/Users/donaldrholman/Desktop/X-Plane 01/X-Plane 11/Log.txt
I am using:
iMac (Retina 5K, 27-inch, 2019
3.6 GHz Intel Core i9
64 GB 2667MHz DDR4
Radeon Pro Vega 48 8GB
macOS 11.6
Xplane 11.53r1 (64 bit)
X55 Saitek Pro Rhino Stick
X55 Saitek Rhino Throttle
144
Re: JD340 v.1.4
I am using:
64 GB 2667MHz DDR4
macOS 11.6
145 (edited by celma972 2021-10-30 20:35:47)
Re: JD340 v.1.4
Dear All, I am unable to use that plane JD340 V1.4 properly. XPlane 11 crashes when loading I am getting that message into the log.txt :
D Light plugin by JARDesign Ver.280321
Loaded: /Users/jjc/Library/Application Support/Steam/steamapps/common/X-Plane 11/Aircraft/Extra Aircraft/340_JARDesign/plugins/CustomLight/mac.xpl (jardesign.3d_lt_editor).
[JD340 INFO]: Starting X-Plane SASL plugin v3.13.1+c1f025b [Commercial Edition]
[JD340 INFO]: JD340 | Aircraft | Start Full
[JD340 INFO]: Loading cursors...
Loaded: /Users/jjc/Library/Application Support/Steam/steamapps/common/X-Plane 11/Aircraft/Extra Aircraft/340_JARDesign/plugins/SASL/64/mac.xpl (1-sim JD340).
Loaded: /Users/jjc/Library/Application Support/Steam/steamapps/common/X-Plane 11/Aircraft/Extra Aircraft/340_JARDesign/plugins/diagnost/mac.xpl (jardesign.jd345diagnostic).
FMGS: 0 : Ver.r76-271021 Oct 28 2021
FMGS: 0 : PluginPath=/Users/jjc/Library/Application Support/Steam/steamapps/common/X-Plane 11/Aircraft/Extra Aircraft/340_JARDesign/plugins/fmgs/
FMGS: 0 : AircraftPath=/Users/jjc/Library/Application Support/Steam/steamapps/common/X-Plane 11/Aircraft/Extra Aircraft/340_JARDesign/
FMGS: 0 : FMGS plugin will try to disable some plugins to avoid plugin conflicts:
FMGS: 0 : Hardware device VID:1103PID:1031 TCA Q-Eng 1&2 was NOT found
--=={This application has crashed because of the plugin: fmgs/mac.xpl}==--
Renaming the mac.xpl file. Plane is loading fine but some buttons are not working, FMS is black..
146
Re: JD340 v.1.4
I am using:
64 GB 2667MHz DDR4
macOS 11.6
If this happen after using instant update - please call me Skype j.a.romanov. - we will check this issue online.
Also, be better if you may put your X-Plane 11 out from Desktop to Application folder.
Re: JD340 v.1.4
148
Re: JD340 v.1.4
Hello.
Please wat is link for dowloader version 1.4 r2, no link on principal website
best regards.
Re: JD340 v.1.4
jaravivar wrote:
Hello.
best regards.
If you have 1.4r1 installed - you may use instant updater to update aircraft to actual version. It available from aircraft menu.
150 (edited by jcdp 2021-11-03 20:45:54)
Re: JD340 v.1.4
jaravivar wrote:
Hello.
best regards.
When loadind aircraft with v1.4R1 I got the notification for updating to v1.4R2 ....
After updating I tried to reload aircraft A340 but I got a CTD with following message ...  :
Updater plugin version: v.151021
Plugin Path: G:\X-Plane11\Aircraft\JD340-V1.4R2\plugins\000_UPDATER\
Aircraft Path: G:\X-Plane11\Aircraft\JD340-V1.4R2\
ERROR: can not copy file from G:\X-Plane11\Aircraft\JD340-V1.4R1\plugins/diagnost/mac.reloadxpl
to G:\X-Plane11\Aircraft\JD340-V1.4R1\plugins/diagnost/mac.xpl
0:00:30.992 E/SYS: MACIBM_alert: La mémoire disponible pour X-Plane arrive à saturation.
0:00:30.992 E/SYS: MACIBM_alert: La prochaine fois, baissez vos réglages de rendu et supprimez les add-ons pour éviter ce problème
0:00:30.992 E/SYS: MACIBM_alert: Si vous n'arrivez plus à redémarrer X-Plane, essayez d'effacer vos préférences dans le dossier Output.
0:00:30.992 E/SYS: MACIBM_alert: C:\jenkins\design-triggered\source_code\core\memory\UTL_memory.cpp:1119
Hardware has not changed in the meantime ...
I followed recommendations but without succes .
What can I do please ?
PS:
V1.4R1 works fine
I use W11
