Topic: Linda and list of commands not visible
I purchased a license of the ZIBO copilot and installed it. Environment:
  • Windows 10 version 20H2
  • X-Plane version 11.53R1
  • Zibo version 3.47.16
  • Active plugins according to attached list
I get the following result:
  • Speech recognition works correctly (when I say "Open File Explorer" the File Explorer opens
  • Clicking CoPilot Setup after first start of X-Plane works as expected.
After restarting X-Plane I get:
  • Linda not visible
  • Menu item PlugIns > CoPilot > Commands doesn't show anything. The other menu items behave as expected
  • Widget "EXPECTED ANSWERS: ... INSTRUCTOR ADVICE:" shown
  • The key set in Settings > jd > copilot > CommandRec activates voice commands, CommandStep has no visible effect, CommandWidgetOnOff behaves as expected
What is wrong?
Re: Linda and list of commands not visible
I found the issue: I had copied the plugin files to the main X-Plane plugin folder, not the ZIBO one.
3 (edited by boond1982 2022-06-17 05:20:32)
Hello everybody.
I have the same issue. No commamnds in the menu bar. See image below. Every plugin is correctly installed.
Thanks a lot for your help
https://ibb.co/89bSHnc
For direct help You may call me via Skype j.a.romanov
We will check all things online on your side.
