Topic: EDLW Dortmund Wickede
Here are Taxiroutes for EDLW Dortmund Wickede regional Airport.
Scenery: http://forums.x-plane.org/index.php?app … file=23011
Map:
http://jardesign.org/forum/img/m/552/t/p1adnk62na1bh51qi01pcn1t8u1saa3.jpg
Instructions:
- Install scenery
- Put both files in X-Life/Airports   and, if you have:  FM/Airports.
- Will work with X-life and FMCar.
The Scenery contains static planes, you can use the "overlayeditor" (or WED) to remove them.
WED.xml is included in the scenery.
2 (edited by SirOTheOne 2016-03-13 16:13:04)
Re: EDLW Dortmund Wickede
the scenery has many, many bugs. Taxiway are wrong, stand positions are wrong.
scenery should be edited
What you want to have is not possible at the moment. If you change the positions and the taxiways
from GA05 to GA12 you will get something like this:
http://jardesign.org/forum/img/m/552/t/p1ae0cnvdpe6c6qs1eg04eu17bd3.jpg
The plane you see has already parked. It does not care about stand direction. The problem
is that this special airport needs "Push IN / taxi out (fwd)", but this is not supportet by
xlife at the moment.
And you won't be happy with this picture...... so I simplified it a litte bit to get a usable airport....
JAR: is it possible to have something like "push in / Taxi out" ??
