Topic: LEPA Palma de Mallorca
ATC routes for X-Life and FmCar
scenery: http://forums.x-plane.org/index.php?app … file=20444
2 (edited by SirOTheOne 2016-03-26 14:20:06)
Re: LEPA Palma de Mallorca
adapted version with no static aircrafts
Thank you for this! The .dat and .txt work like a charm!
I can´t figure out what to do with the no static data. If i put it in the scenery and replace the file there, the whole airport is empty. Not only all static AC are gone but also all buildings. Can you give me a hint?
Chris
If you wish to remove the existing static aircrafts, just unpack the 'LEPA_Nostatic.zip' archive to you 'custom scenery' folder. Don't forget what "LEPA_Nostatic" must be located higher then LEPA main scenery in the 'scenery_packs.ini' file. Please don't forget about this.
Hope it helps, MasterTRL
5 (edited by SirOTheOne 2016-05-15 07:42:41)
Hello luke97 and MasterTRL
with the actual X-Life, you don´t need to exchange apt.dat file, please use the original and the new LEPA.txt file (see attachment) in X-Life folder / Airports
6 (edited by joomie 2016-10-30 22:42:38)
Thanks, but the .txt needs to be corrected. The size of aircraft doesn't fit the ramp start.
Exampe:
http://jardesign.org/forum/img/m/436/t/p1b0brr8ja361nrpupt1lm113e93.jpg
Taxiway Y3 is named Y4 in the .dat file.
7 (edited by joomie 2016-10-30 23:18:41)
i checked the LEPA.dat and LEPA.txt file in detail and there are so many corrections to be done. It's a bit annoying that people upload work in progress stuff and do not mention that. The LEPA.txt needs to be reworked/ corrected completely and the LEPA.dat contains a chunk of errors.
Don't get me wrong. I appreciate your effort. I know, that this is a lot of work.
One hint: If any of the .dat or .txt file gets an update: It is possible to update the initial post at the top instead of uploading another version in parallel to the outdated file(s).
For me I can't unfortunately load the LEPA airports in Xlife. It said me that LEPA was not  axlife compatible airport, see the map....
How can I do to have like on other non official xlife airports the functionnalities ?
Thanks a lot
