1 (edited by SirOTheOne 2016-02-23 15:57:49)
Topic: LOWL Blue Danube Airport Linz
Hello to all,
here are the new ATC routes for X-Life and FMCar for the airport LOWL Linz, Austria
link to scenery: http://www.x-plane.at/drupal/node/233
please test and give feedback
thanks
Re: LOWL Blue Danube Airport Linz
Thanks a looot! if you do not mind, I will do some improvements and add this (realy cool) scenery to MAP, upload .dat file to server and also explain what inprovements was used. Ok?
Also, I post a non-static scenery (scenery with exclusion zone only) to remove static aircrafts. This folder should be placed to Custom scenery too. I just make a scenery with exclusion zones, export it and delete apt.dat (save only .dsf)
http://jardesign.org/forum/img/m/22/t/p1ac7futsvqmo1ie61498huego83.jpg
make some turns as just an intersection
http://jardesign.org/forum/img/m/22/t/p1ac7g2k7f1rlle5c1fmn3p6vbb3.jpg
better is:
http://jardesign.org/forum/img/m/22/t/p1ac7g31b91cld14p91quu1nsehnq5.jpg
make HoldShort-Runway connection with ONE line
http://jardesign.org/forum/img/m/22/t/p1ac7g5h82qh555djc2q0ou03.jpg
better is:
http://jardesign.org/forum/img/m/22/t/p1ac7g7op6109t1f1tf9l1kun18433.jpg
and:
http://jardesign.org/forum/img/m/22/t/p1ac7gfi9519ils0j128agcncb93.jpg
Improve big-radius Turn with "rounded line inside a corner"
http://jardesign.org/forum/img/m/22/t/p1ac7gbfc2119f14kj42f10a2d153.jpg
and
http://jardesign.org/forum/img/m/22/t/p1ac7gepsd18q61k941vuj1qi11ak73.jpg
Change runway ends to this
http://jardesign.org/forum/img/m/22/t/p1ac7gg42ectp1i4h1t395es7653.jpg
http://jardesign.org/forum/img/m/22/t/p1ac7ggkj31ra279e5e51pm23555.jpg
make some changes at Gate Editor to avoid troubles
http://jardesign.org/forum/img/m/22/t/p1ac7gieu91snfs3kfl21fq6kpq3.jpg
