Flew EIDW to EHAM. Everything went well except for a couple of minor observations with AI aircraft when taxiing at EHAM. Shortly after exiting RW18R I could see a Citation X flying towards me. It then disappeared into the ground just to the right of the taxiway. Then shortly afterwards, I could seen an AI aircraft in the distance circling and then appeared to dive towards the ground.
Not sure if there is a log I can send you that will show the AI aircraft activity at EHAM.
Otherwise everything is working very well.
