301
You don´t need a link, just download the full package from x-life site and extract it. Copy xpl files in your x-life folder
302
I would like to use the route that X-Life is offering (presently I don't know if their are same) to let everything to be
original X-Life. I am using the JAR A330 (X-Life transfers its flight plan directly to the FMC), on my iMAC27.
Start point EDDH parking lot 18 (FollowMe car isn't appearing ?!) I am preparing the aircraft from cold and dark (it takes
me 15-20 minuts incl. programing the FMC) Then I can already see aircraft traffic (sometimes  collision with other aircraft on taxi ways).
In 4 hours I will start another test flight.
Captbullett I wrote you in the thread about SMP3 have a look
Concerning SMP3 it is obviously that there is a strong conflict with X-Life !!
Last time starting X-Plane with X-Life and SMP3 not only X-Plane stocked but also OSX every 20 seconds !
Then I unchecked SMP3 from administrator list and everything was fine.
After a while I checked SMP3 on and actualized METAR - no crash..
This is totally crazy..................... !
sound good to me lets use // *  http://onlineflightplanner.org   ///  so we can download the plan via the widget and also get the same data from the PDF that will be provided it will give the fuel and the load data also and other data to help match the current data ...
this is a big help if then we all send a bbox.txt before we close the X-Plane down to JAR this will help him also send the log.txt
thank-you for your help,
this is the route I will be using and set as a control if it is a good route I must test it one time first to see if it works !
EDDH SID WSN UN125 EEL STAR EHAM
I would like to propose to take the very short flight from EDDH to EHAM as common test flight route
303 (edited by SirOTheOne 2016-03-02 16:00:18)
@Eugeny
watching the scene LIPZ - > CTD (after about 15 min), see log
304 (edited by captbullett 2016-03-02 17:42:54)
How is everyone today, I am testing the ;
today using the A330 and I want to make sure that it is a good route for a control test route, and I do not see why not but one never knows until we try it out and then I what a return route so we do a down n' back for testing.
So, this is my thought that if we all are running the same route if any issues show up they will be easer to track if we are all using the same flight plan.
thank-you for you help,
Ps, this is the return flight plan the was generated by //*  http://onlineflightplanner.org  ///
EHAM SID ANDIK UN873 GRONY UM105 EEL UN125 WSN UL23 HAM STAR EDDH
Now these two routes should be the control route after I test them  it is work in progress right now.
305 (edited by SirOTheOne 2016-03-02 18:09:12)
Well,
flying from EDDH to EHAM on route: EDDH SID WSN UN125 EEL STAR EHAM with an A320neo on an iMac 27ret, i7(4) without any trouble or problems with x-life beta8 hf2.
I´m also a developer and i can understand the f...ing problem, CTDs and no CTDs -> where is the bug?
edit:
one bug i had found, i landed an runway 09 and it´s not an ils approach, it´s a VOR approach
and the approach was very windy ;-)
306 (edited by Geekfried 2016-03-02 17:52:38)
Hi There,
did a testflight with the 320neo from EDDH to EHAM too but not that good result for me.
I got an CDT while descending arround 7000 feet after EEL.
Attached the log of the Flight. Hope it helps kill those anoying bugs smile.
307
this is what the HF2 is for to track the data and so my train of thought is for everyone to use the same route so there is a common thread then we can see how each X-Life acts on the same route and shake -out the bug!
Well,
308 (edited by captbullett 2016-03-02 18:34:18)
good day,
just started XP and CTD , version 10.45r1 this is the data that we are trying to collect now. and this CTD was due to the FMC not the X-Life plugin.
Attachment icon Apple CTD of X-Life on March: 2 :2016.txt 60.74 kb, 267 downloads since 2016-03-02
Attachment icon bbox_log.txt 119 b, 253 downloads since 2016-03-02
309
Just made a flight from LPPT to LPFR (2 airports I made the ATC routes). First thing, is that I could not create the flight plan from the xx-life plugin. When I clicked generate FP, nothing happened. I had to create the flight plan manually, so I put there: LPPT SID TROIA A5 ODEMI STAR LPFR.
So the ATC gave me the clearence without the SID from Lisbon. When I was on holding point of rwy 03 at Lisbon, I saw an aircraft from x-life simply passing over my aircraft big_smile
The rest of the flight was ok, without any problems until arrived on the gates.
Curiosity, I had a flight behind me that parked side by side with me big_smile
Besides the bugs and some other things not like real life (At least for now),,,,,,,,,,,,, I had a pleasure making this flight.
310
good day,
bbox.and log.txt or your post just does not help !
311 (edited by captbullett 2016-03-02 20:10:36)
now I have got every thing straight I found a free EHAM at the .org that works and does not CTD the XP app
so the EDDH to EHAM it on for the test route and the followMeCar will work if you remove the old txt and dat file in the Airport file, and let the FMC reload after you install the scenery pack.
this is a very good scenery pack and looks as good as the pay-ware.
http://forums.x-plane.org/index.php?app … wfile=5516
312
Can we not use our own airports at all anymore with the latest X-Life Deluxe version?
I am getting the message that my new KBOS is not an approved airport and the gates editor doesn't open.
That's disappointing. While we beta test on the "approved" airports it would be kind of nice to be able to test our own airports as well.
313
Test flight completed Hamburg Amsterdam. No CTD and ATC went well. I set my cruise level too low because I thought it was much shorter than the actual distance but X-life behaved properly.
Two slight issues:
On departure Runway 05 from Hamburg I was asked to hold short for an arriving plane. I was never told to position and hold even long after the plane had vacated the runway. As soon as crossed the hold line (which I should not do) I was told to position and hold and the flight continued normally.
Secondly, I reached top of descent just before EEL. I reported TOD and was given my STAR. This was EEL1A which on the charts begins at EEL. But when I entered this into the FMC the flight path was 10 miles south of my current position (just before EEL) and I was off course. The autopilot turned to intercept the new path but then did not intercept correctly so I had to fly the approach in heading mode and then manually. I was flying the JAR A320 NEO latest beta. I guess the STAR issue is a problem with the A320 rather than X-Life.
Overall very good flight. I have pasted the logs anyway because sometimes successful flight data can also be useful. I will report other CTDs if I have them.
314
Доброй ночи. Интересную картину наблюдал, подпись к самолету есть, а самого самолета нет. А после взлета еще и высота отрицательная.
Good night. An interesting picture was observed, the signature to the aircraft, and no aircraft. And after takeoff and the altitude is negative.
http://jardesign.org/forum/img/m/2023/t/p1acsq5c0h1n5ipmlsobteh2v23.png
http://jardesign.org/forum/img/m/2023/t/p1acsq5c0i42j5kfcb1j2npoa4.png
315
Where do I get the file bbox ?!
good day,
316
it is in the  //* Main aircraft folder/A320Nev2/bbox
or the //* Main aircraft folder/A330/bbox.txt
and you will find it right below the airfoil folder if your file system is in order .
So much,
good day,
317
have you up-dated to the latest version 8 with HotFix 2
thank-you,
Здравствуй,
вы обновлялся до последней версии 8 с HotFix 2
Спасибо,
318 (edited by Sloboda 2016-03-03 05:17:37)
why ATC don't work on flightplans where the airports don't have ATC routes ??? ATC need the ATCroutes of airports for work ?????
When i try to make a flightplan with a destination who don't have ATCroutes, X-L say "the alternate airport is wrong".
319
Hello, noeone for answer me ?
http://jardesign.org/forum/viewtopic.php?pid=9702#p9702
Thank you for help, i really would like to start to create ATCroutes
320
thank-you,
Здравствуй,
Спасибо,
Yes of course updated.
321
In the file log.txt errors have been found associated with objects from the OpenSceneryX library. The contents of one of the folders in the screenshot. The OpenSceneryX library updated.
"Failed to open D:\Games/X-Plane 10//Custom Scenery/OpenSceneryX/objects/aircraft/jets/heavy/a320/frontier/object.obj: the file cannot be opened.
X-Life Object load error: D:\Games\X-Plane 10\/Custom Scenery/OpenSceneryX/objects/aircraft/jets/heavy/a320/frontier/object.obj
Failed to open D:\Games/X-Plane 10//Custom Scenery/OpenSceneryX/objects/aircraft/jets/corporate/citation_x/unlit/object.obj: the file cannot be opened.
X-Life Object load error: D:\Games\X-Plane 10\/Custom Scenery/OpenSceneryX/objects/aircraft/jets/corporate/citation_x/unlit/object.obj
Failed to open D:\Games/X-Plane 10//Custom Scenery/OpenSceneryX/objects/aircraft/jets/corporate/citation_x/lit/object.obj: the file cannot be opened.
X-Life Object load error: D:\Games\X-Plane 10\/Custom Scenery/OpenSceneryX/objects/aircraft/jets/corporate/citation_x/lit/object.obj"
http://jardesign.org/forum/img/m/2023/t/p1actoliiptoosg4bh1gp81a053.png
322
Test flight EDDH - EHAM, using JAR A330
EDDH taxi, ground trafic, ATC No problem (I set SMP3 to default) 30fps
During flight FL 240, clouds and 22 fps
Descent I go clearance to RWY 24! ATC bug: Clear ILS 24 but it is a VOR appr
From now on ATC is giving order for ILS - not usable
Result: appr manually, reciving abbort landing........
Frame rate sink near EHAM to 11fps
Go Around re-program FMC for ILS RWY36 - no ATIS and lot of aircraft on taxi
323
Hi..just use the same destination for that. So, if you go from LIRF to LFMN, just use LFMN again for your alternate airport.
324
Thank you. It's exactly what i do. That don't work.
ATC just match with airports where there are ATC routes. 27 airports in the world .... TOP !
And like i say in my other posts... But nobody answer... We can't try to make ATCroutes 'cause the airports must be validate.
How can we learn to create if we can't test.
Perhaps i will know a day in the future if someone would answer me...
325
Thanks for the info. I don't have neither of these 2 aircraft...
So much,
good day,
