Re: XP11.50 JD330 v.4.2
Hi, i have the same problem with the old version.
The Custom Soundpack (Trent700) doesn´t work again.
Someone with this issue?
I have the same problem that the spoiler is prepositioned and the autobrake is on when the plane lands, but the spoiler and autobrake don't work after the plane touches down. Another question, during takeoff check FULL UP, FULL DOWN, FULL RIGHT, and FULL LEFT there is no sound, in the previous version there was a check sound to indicate that the check was done, why is this, look forward to your reply!
53
You may contact support directly via skype j.a.romanov - we will check this issue online.
when on ground there's a huge friction that doens't allow me to move unless i push thrust sometimes above 50%, i only have the issue with this aircraft, taxi is very difficult like that, is there something i can do to change this behaviour?
I just downloaded version 4.2R3 and my spoiler axis no longer works. Is anyone having this issue? I am using x-plane assignment for speedbrake and tried a different controller just to rule out an issue.
My issue is resolved. I was unaware of a new menu entry to toggle spoiler axis on/off.
Jordan86
Friend, check out the X-Plane.org forum for a fix.  Had the same problem and the fix worked for me
58
I have a different problem.  I am using version 4.2 r3 and there is no rain effect on the glass.  Rain effect is enabled in the menu, but nothing happens.  Has anyone encountered such a problem?
59
Dimitrius wrote:
Jordan86
Hi Dimitrius, do you mean rolling friction coefficient as explained in this topic?
https://forums.x-plane.org/index.php?/f … er-to-low/
what are the implication of doing that (other than solve this problem of course)?
Hi Jordan86
Yes, that is exactly the solution. Everything is fine, the plane is rolling as it should. Now I taxi at idle
61 (edited by Alexandre Paumgartten 2021-07-02 17:02:20)
Sorry, i can´t delete.
62 (edited by X-Kompi 2021-07-04 00:42:08)
A330 V4.2R4 works fine. I just bought it. Like it but….
1. How can I open Cockpit door like A320?
2. Why I can’t turn the knobs by the mouse wheel? It’s much more convenient than pushing the mouse button and moving the mouse around. It works on A320 and I love it.
3. The engines should be much more round. To many edges in the circuit
63 (edited by albatrolejano 2021-07-12 05:41:25)
hi Mr Romanov.
Everything great with this bird (I use v4.2 rc4  , xp 11.55), but ,
a weird thing here with my tca quadrant of Thrusmaster airbus,
I have followed all the instructions, (assigned key TCA_MAsterSwhitch1ON to eng1 on)  but when I give ON in the mcdu to the option activate TCA QUADRANT, this simply does not activate, and keeps OFF selected, I have tried several times and nothing happens (also reinstall the aircraft  and  i use  it in other aircraft without problems).
I can use my TCA , but only the  thrust level, not the ignition knobs.
What can it be?
thanks
64 (edited by towfique1111 2021-07-22 00:36:48)
JD330 for X-Plane 11.50
What new:
v.4.2R1
+ BAT indication on overhead panel fixed
+ Special points drawing on ND (on curved pathline) fixed
+ Chrono work fixed
+ Clock reworked
+ Alt CNSTRs indication on PFD fixed
+ V/S FCU indication fixed
+ Coordinates on MCDU INIT page (wrong format fixed)
+ TCA Engine Master Switches Support improved
+ Profile altitude for alt CNSTR points recalculated
+ NPA approach calculation and indication improved
+ ILS Information on PFD fixed
+ MDA entering fixed
I cant find 4.2R1 ..... as i purchased in the version text it is written 4.0R2.
Please help
65 (edited by towfique1111 2021-07-22 00:35:49)
im new in jar design ... i purchased the product and in the zip folder the product is 4020... ( inside version text it says JD330-V4.0R2 ).... Im confused which one should i download .... as it seems to me v.4.2R1 is the latest one but there are two files in the installation sector ......1 is "Download link for version 4.2.3" and the other is "Download link for version 4.2.4"....
which one is the latest ? ( i downloaded both files and in both, the version files does not state any " 4.2R1" )
please help
please help
Download in http://jardesign.org/forum/viewtopic.php?id=17134 - look on pages for download link for version 2.4.2 you get JD330XP1150_4240.zip and this is the last version.
67
whats the serial number?
68
Hi guys...so nothing new about the issue with the Soundpack (Trent700)?
Come on, someone to help?
HELLO.
Current version of a330 4.2rx freezes when running pilot2atc in vulcan xp 11.55.
Anyone test for this?
del2054
Doing quite a lot of flying with the A330 on OnAir while I'm saving up for the A340.
All that got me thinking, why isn't there a mod out there that adds mouse wheel support to control the dials and buttons, only the AP panel has mouse wheel support. Hope this can be added to the plane smile
71
Good Evening everybody, hope you are doing great. Today I was doing a flight from KSFO to RJTT (Tokyo) and encountered with a bug that I can't really figure out why it happens. The route starts twisting at around this point in the map, it does not matter what latitude I fly at. No matter how many corrections I make to the flight plan, after that specific point in longitude, no mater how north or south I fly over the Pacific Ocean, route will twist.
Any ideas for resolving the issue?
https://i.ibb.co/SrVRZQS/Untitled2.png
72
how can i get a serial key
73
albatrolejano wrote:
hi Mr Romanov.
What can it be?
thanks
Hi, exactly the same thing happens to me. Mr Romanov or someone else could answer and we would greatly appreciate it.
74
hi Mr Romanov.
What can it be?
thanks
The best and faster way for support - call me Skype j.a.romanov - we will check issue online.
75 (edited by dsi_92 2021-09-04 20:56:21)
I've bought jar a330 half of year ago, and there were no issues.
I always download new version and now have xp 11.55r2 and jar a330 v4.2r4
However, today something went totally wrong. I did not update anything except OS (I have Mac OS Big Sur updated to 11.5.2 ver), but after that jar a330 is not starting at all.
My log.txt contains following
FMGS: 0 : Ver.r41-011120 Nov  1 2020
FMGS: 0 : PluginPath=/Users/sdormidontov/Library/Application Support/Steam/steamapps/common/X-Plane 11/Aircraft/JD330XP1150/plugins/fmgs/
FMGS: 0 : AircraftPath=/Users/sdormidontov/Library/Application Support/Steam/steamapps/common/X-Plane 11/Aircraft/JD330XP1150/
--=={This application has crashed because of the plugin: fmgs/mac.xpl}==--
What I tried:
- Delete most of plugins
- Delete all custom scenery
- Replaced fmgs folder from older versions of jar a330
- Checked that another commercial aircraft (x-crafts e175) is loading normally.
I'm lack of ideas, nothing works.
Can you help me?
p.s. I've also found that absolutely same problem with my jar a320 aircraft, so I'm unable to use both of them.
